Three in the rear!
need2boat
I ride with a few guys that use an old pad behind the new pad on the rear brakes. They only do it on the outer pad to reduce piston travel.
I've not done it but wanted to hear if this has been around for years? pros cons. Sorry I didn't snap any pics of what it looks like. The pics below show two rear pads ones new the other got 20 hours on it.
i have to do that on one of the kids 98 RM80 the piston sticks way out on those and it doesn't seen to have a rear brake i'v looked at a few rm80s about the same year and they all seem to be that way [don't know if they worked didn't ride them] i messed with it and messed with it no brakes i ground all the lining off one of the old pads and stuck it in there and BOOM brakes out the wazoo it still in there and working fine
Yea I've seen it done on a few of my friends that ride KTM and use the same pads as my 310. There is more then enough room once the pad has a few miles on them but I've never lost brakes. That said around 50-75% of pad life I need more fluid due to the piston hanging out so far. I guess with the shim that would be less of an issue.
It might but I'm not sure it's work doing that. I'm not having issues as much as just wondering how many others do it and the advantages to it.
well the OE set up ought to hold enough fluid to push the piston clear out of the caliper i had that RM all bleed out full of fluid and good pedal just no stopping power it was odd never heard of such a thing be for or since the extra pad deal was a well try it and see thing and it worked as far as benefits it acts as a heatsink/ insulator helps keeps the fluid from overheating
