Throttle Position Sensors??
F1000
The TE449 has two, I have removed the second butterfly. The one sensor seems faily obvious as a thrrotle poition sensor, I adjusted this to .8V. The second one seems to work a servo that adjusts the throttle position slightly. What does this second throttle position sensor exaclty do? Does the ECU take feedback from it? How is this adjusted and does this affect the starting ability of the bike?
Still having difficulty starting my bike, runs perfect once started. The TPS sensor (non butterfly), seems to have little affect on the starting, even when pushed to the limits in both directions. I did verify the voltages on it prior, set it to .8 and it went to about 1.5 wide open throttle. It doesn't seem to make much difference no matter where I set it. I reinstalled the secondary butterfly, and that made a difference on starting, but seemed inconsistent. Again adjusted that from stop to stop and it just did not start reliably. The bike runs on when starting. almost like it is running with the starter pressed, but just not quit. Have to hold the starter for a long time and lucky if it catches. I am not sure it if it is too much fuel or too little. Very odd. Worse when hot. I am beginning to suspect the valves. How picky are these bikes with the valve clearances? I need to make some accurate measurements, but quick measurements indicate the intake are loose, .007" and exhaust was slightly tight at .009". Is the run on when starting an indicator of a lean condition?
Also, I don't believe the quick TPS adjustment does a damn thing.
I never hold my starter on for more than 1-2 seconds. It usually takes 2 or three of these small bursts to get it idling when cold. Butterfly in, Akro exhaust.
