TLS Rear Brake! (found in the R & D parts bin)
hva-factory
CH Sponsor
Thought you might like this. I found one of these assemblies a couple of years ago in a secret location in Sweden. I since found another and decided to use them on my factory 300cc (yes you did read that correctly) WR's. They don't work any better than the already excellent sls rear, but they are pretty trick! I am using the bikes in the British Twinshock Enduro Championships.
Hello,
It looks like just modifying the front TLS brake linkage on to a rear backing plate. Drilling a hole and welding as shown above?? Or is their more going on that we can not
see. Maybe thats a new special option - you can work up for us. Really ! does it not work any better ??
Gary
Yes, it is mods to the front setup. Don't be fooled thought - there is quite a bit of machining to do, as the hidden cam is too long and fouls the swing arm - so that all needs work. The other one I have has a one piece arm - not the 2 parts welded together (that means a mod to that cam too....)
Be careful you don't set your machine shop alight machining the magnesium plate!
Andy
So this is a SLS brake plate converted to TLS? I have seen how to do that on Suzukis before. Drill the plate, add a second cam and then modify both cams and the shoes and then you have a home made TLS.
