Took off my valve cover, now it won't start
foxriderar77
I have a 2000 TE 410E and took off the valve cover for inspection after I heard noises from the top end. Turned out to be my chain tensioner was not adjusted correctly, its a manual one. I put the water pump impeller back on and the valve cover, used RTV gasket maker. After I put it all back it wont start, looks to have spark, getting air and carb looks wet. I am thinking I miht have a timing issue but I dont really want to pull it all apart again.
In short what should I check if I have spark, air and fuel? I didnt take off the chain so I doubt timing would be off. Can the valve cover and rockers be installed incorrectly?
