Top End/Athena Kit Advice on '07 TE250
MotocycleWriter
It's time for a top end on my 07 TE250. Think I'm going to go with a 300cc kit. Any advice on doing this mod or any good go-by's? I want to make sure I have everything ready when I pull her apart: lubes, assembly lube, special tools, torque specs, etc. I am ordering a shim kit so I will have that ready. Good time to adjust the valves, too. Anything else I should do when it is apart? Thanks!
Wonder if I should remove the motor from the frame? I was planning on doing a thorough carb cleaning and a rebuild if I can find a kit.
