Trailtech computer and a supermoto???
sharpie1
I hate trying to figure out what wheel size to program into the Trailtechs. Are any of you SM guys running one? If so, do you mind sharing what you have programmed in for a 17" wheel?
I just picked up a vapor for my 510sm. I just marked tire with chalk and with me on the bike i rolled the front wheel one revolution then measured the distance in mm and there you have it. Or you can just wrap a piece of rope around the front tire while its on a lift and measure the circumference but i think that will be less accurate because all the weight isn't on the tire. There are also mathematical equations to figure it out with the diameter but who wants to do all that...hope this helps
With my old bicycle computer on the last bike, I just did the chalk method and it worked perfectly.
Just chalk a straight line on the sidewall out to the edge of the tire. Set a tape at 0 with the line straight down on the ground, roll the wheel until it comes around again and measure that distance. What's nice about this method is that it takes care of tire differences.
