Sizzler
As I have got both 17” and 21” front wheels for my TE630, I need to be able to switch the speedo from one to the other. As this is not an option with the standard 630 dash, I have gone for a Trailtech Vapour Stealth unit, with the dash for “idiot lights”.
This is a pretty nice bit of gear, with advantages and disadvantages compared to the standard dash.
•It is slightly smaller and sits lower than the standard
•The shiny black finish of the dash doesn’t quite match the matte-grey of the old dash
•It has a tacho that you can actually read, with shift and over-rev lights (although, on a big single, they are more bling than useful)
•The trip-meter isn’t as flexible as the standard
•It does have a temperature gauge, with high and danger settings.
Wiring of the main unit was pretty straight forward. The tacho and temperature have their own sensors, and it just connects to the standard speed sensor (although they do supply one).
The challenge I had was with the connections for the other lights. The Husqvarna wiring diagram gave a few hints, but not definite connections, particularly for the low fuel and neutral lights, which are valuable. Armed with a multimeter and a pile of spare fuses, this is what I got.
The standard plug that connects to the back of the dash is a 26-pin, with 1-7 across the top row, 8-13, 14-19, and 20-26 across the bottom row. Not that as this plug is reversed; the numbers go from right to left.
•2 - 12v – switched power supply
•20 - 12+ switched power supply- this comes on with the ignition.
•3 & 14 - High beam
•3 & 16 - Low Fuel
•5 & 17 - High beam
•5 & 18 - Left Blinker
•5 & 19 – Right blinker
o(I put a 5w diode in each of the blinker wires, before connecting them to the one dash light. This prevented the single dash light making both indicators flash)
There are only 4 lights on the Trailtech dash, as opposed to 5 on the standard. But, as Australian-delivered bikes have their headlights wire on, there is little point having a light to tell me that it is there (I found the constant green light on the dash a bit irritating).
The wires supplied with the dash are pre-soldered, so they are pretty rigid. To make a plug, I put a bit of plastic over the standard plug, and punched the wires through into the holes. I then glued them in place with 2-part epoxy. When this was set, it pulled apart like a normal plug (the bit of plastic stopped the two plugs being glued together).
The dash was supplied with a set of LED globes. Use them.
I hope this makes thing easier for the next person who wants to do this.
•3 & 14 - High beam
•3 & 16 - Low Fuel
•5 & 17 - High beam
