Transmission seems locked
Chazaag
Hi guys- I have a 1972 Husky 400 CR I’m trying to get going. Engine spun over easily, trans went through the gears (albeit in the rough side). Took the primary/trans cover off, put it back on, filled with fluid and it seems like I’m locked between gears. I’m guessing I’ll have to split the cases, but any sage advice or where I can get trans parts would be a good start. Many thanks in advance!
Nice looking engine
5-speed or modded to six
Did you take the transmission? Apart/ split the cases already.
Did it ever shift okay since reassembly
You say you took off the clutch side yes
Also are you able to push through the kickstarter
Drain the oil. Take the clutch side off again. See if it shifts through the gears. Check for anything between the crankshaft gear and the clutch drum gear. Maybe something fell in there and it's preventing it from moving.
Don't split those cases just yet.
Welcome to Cafe Husky
Were there any large metal filings on the drain plug? It should be free of any metal filings. Just to make sure the trans hasn't exploded put the bike on a stand with the rear wheel off the ground and try to shift through the gears while slowly spinning the rear wheel. It should click through the gears with ease. If it doesn't then you'll need to schedule open-case surgery.
Parts have become scarce but not impossible to find. Ebay is currently the go to place but its can be pricey if you're in a hurry. Other wise you can post here for what you need and someone may know where to look.
