suprize
Got any neat tricks and tips for running these bikes? just add them to this thread.
There are a number of "standard tricks "everyone does but i will list the ones i know for those new to the fold
. when refitting front wheel, leave all the bolts slightly loos and bounce everything around to centre the bolts before tightening it all up.
. with the wheel/axle nut, spin the wheel backward before jamming the brake on and then do the nut up without letting the brake off.
. make sure you secure the front brake cable to the fork leg with a zip tie or clamp to prevent it bowing into the front tyre on compression.
Always silicon the pipe to barrel join and the muffler to pipe join and leave for 24 hrs before use. Holds together remarkably well.
Make sure you loosen the top triple clamp and tap it down if you have tighened the head race bearings.
i mix a bottle of 10 wt and 5 wt to make a shandy of 7.5 wt for the forks which suits me at 83Kg's
Thats all i can think of for the minute...feel free to add .... im keen to learn more
