TTO PPR setting 14 310R
2wheeler
So I have the Tach/Hour Meter connected directly to the wiring harness plug which connects to the coil. (not my pic)
The units default setting is 1.0. Interweb says 1.0 and 0.5. One manufacturer states 0.5 for most efi engines. Factory idle is stated as 1950 rpm.
Started the bike and let it idle.
At PPR-1 tach reads around 920 with max rpm of 1200
At PPR-0.5 tach reads around 1860 with max rpm of 1860.
It would appear 0.5 is the correct setting. Whatya think?
I've got one on mine, but not home for another week.
If no replies, I'll check and get back to you
Mike
Sorry Mate - forgot all about this!
Checked mine and its set at 0.5
Idle speed is set at a tad over 2000.
Think mine is an earlier version to the new model TTO - I had to look at the instructions to remember where the buttons were, and they are quite different to mine.
I don't have a clock setting, but I do seem to have a sensitivity(?) setting and a refresh rate setting - set at Hi and Fast if yours is similar.
It's a good little tool - shame Husky couldn't have integrated into the dash!
Only downside is relating the miles covered to the time running - it highlights just how slow I ride :-)
Mike
No worries! Thanks for checking! Left mine on 0.5. No sensitivity or refresh rate here
Yes, too bad Husky shipped the bikes without the hour meter working. And for me not installing one when the bike was new.
Haha! I can relate to slow! Had this bike for a little over 2 years with 650 miles on it now :eek:
