wallybean
Mini-Sponsor
I was feeling a bit more mobile today so I decided to install my Terrapactor tires and tubliss setup on my WR 144. First off I weighed all tires and wheel tire combinations before and after. The Terrapactor 80/100 front and the 110/100 rear are virtually identical in weight to the slightly worn stock Michelins, within a couple of oz's on both. I was kind of amazed at the Husky use of fairly light weight tubes both front and rear on the WR 144. My 06 WR250 had nice heavy weight tubes that are very tough, heavy but tough. Ok, after drilling a new hole for the larger tire lock next to the original valve stem hole, mounting up the tubliss inner liner is a breeze. Heed their call for use of Armour all on the rim and liner, you can't have enough lube in there. It makes the seal between the liner and tire happen easier. Mounting the tires is very easy without the tube being a nuisance. Just follow all their instructions and it is really a breeze. Ok, what did I gain as far as unsprung weight. I actually lost about 6 oz's on the front. Again the stock tube is very light weight. On the rear I gained right at a lb in unsprung weight over the stock set up.
So what is the bottom line? If I was going to go to a heavy duty tube as I always do, I would gain at least a lb in the front and 2-3 lbs in the rear. I don't have to worry about pinch flats
I gained a little unsprung weight loss over stock in the rear and a bunch over heavy weight tubes. I can now run very low tire pressures without any worries, although the Motoz tires are awsome and probably as pinch resistant as they come. I will just put a little slime in the tires and carry some tire hole plugs and co2 and I am set for anything.
Now I just need to finish healing up and get south for a couple of weeks of flogging the scoots. OBTW, once again I am writing this with ice packs on both knees and my right arm.
Walt
Walt
