TXC 530 build
Bigtoy302
So in November I seized my 08 TXC 510. I then ordered the 530 kit from Toxic moto with the forged and coated CP piston which took several months to get. Now I'm finally getting around to tearing it the rest of the way down and checking everything out.
New piston and bored/ re Nikasil cylinder.
Bike torn down.
Cases split.
Checking the run out on the crank. Measured .004" which is way to far out.
Pressing the crank apart.
Big end of the rod. has a funny wear pattern. Same as on the pin. Measured the small end and it was .001 out of round so I ordered a rod kit from Bills. Should be here next week. I also have the kx250f rod bearing ordered also.
New pin and KX250F rod bearing (20 rollers instead of 19).
Cases ready to go back together.
Zip tie ring compressor.
Stock wimpy stator.
After I rewound the stator. I also installed a Trail tech rectifier because the rewind converts to full AC and more current.
Sprayed it with insulating varnish to help protect it.
I also mounted up one of my LED light bars I make. 5100 lumens. 63 watts.
Can I get the specs of that Kawi bearing, model year please?
Any oil passage mods in the crank? I just read a note about it but not very specific, just it was done.
Thanks, Jim
Got the number...
kawasaki part number is:
13034-0014
KX250F 2004-2009 Big End Bearing.
Still wondering about oil mods.
Thanks.
