Guys,
Been toying with building the ultimate post vintage air cooled Husky 250 MXer
, over the Winter, as I fell into a running 83 & a 84 XC parts bike, In the last couple of weeks. Does the steering head angle change in 84 (30.5 to 28.5) really make that much of a difference turning. I’ve gotten so used to the 80’s frame geometry & steering with the rear wheel, is it worth it?
Also what’s your opinions on stock Plastic vs alum tanks & seat combo’s
Here’s the break down on what I’ve got to toy with. Sort of mix & match style.
1) 83 XC 250 with a 82 250CR pipe… runs great, metal tank & matching seat
2) 84 XC 250 with locked up bottom end, No pipe & pretty hammered.. has plastic tank & matching seat
3) Both have the same suspension as the CR (18.5 Ohlins on back, & long travel 40mm forks).
4) Also have a pair of 81 & 82 CR frames & Swingarms & mating 17” Ohlins shocks.
Is there a better combo, then a 83 air cooled motor in a 84 frame (remembering the 84 CR was watercooled)
Or would it be better in a early frame using the 83/84 swingarm & suspension.
I know it’s going to be Winter in NorthEast before you blink, so has any one gone down this path or Is it just a waste of time
Husky John
Husky John
