Valve clearance check and change
sorry missed the important bit it's a husky 511 smr 2011.
I think to free up the cam chain tensione you have to undo the cam chain tensioner which means taking out the see through tank.
You do not need to remove the sub-tank to release the cam chain tensioner for a valve adjust. Also, very important to lock the crank at TDC before you remove the cam chain. Trust me on this. I went through valve adjust hell a couple of months ago on my TE 511.
Also, BMW 450x used the same motor. Try googling the BMW to get additional info. I got my shims from the BMW dealer.
