Vintage Aftermarket Performance Parts
Vinskord
Time to document those aftermarket parts used for our Huskys back in the early 70’s before it slips my mind. In that period of fast changes for improved performance, ease of maintenance, or for lighter parts, the aftermarket was full of offerings.
This exercise will keep to the parts available in the early 70’s – nothing modern here.
Starting off with Handlebars and Triple Trees:
Hallman Bars – Arne Kring Bend
Andre’s Bars – CroMo with matte finish and lighter than OEM
Titanium – Notice the Crossbar, larger diameter tubing than normal – these are light!
Titanium Triple Tree – These are made up of welded plates, OEM are pressed steel. 1lb-11.7 oz lighter than OEM.
Next are Shocks and Brake Stay. After the OEM Girlings wore-out there were a number of options:
KONI GP – Alloy Bodied
KONI
Curnutt
Poppy Elephant – A popular mod that used KONI internals.
Alloy Brake Stay
Misc items:
Footpegs:
Alloy
Steel
Alloy Front Fender Bracket
Torsten Hallman Racing Cables
Mikuni 36mm Carb w/ O-Ring Mod
Intake Adapter and Mikuni Mounting Flange
‘Pro-Bowl’ Clear Float Bowl
Fenders, Seat Base, Air Cleaner Cover:
A&A Fenders – Front, Inner, and Rear. Same shape as the OEM alloy fenders. These are made of ‘Kydex’ – as used in aircraft interiors. These are also the fenders used in 1972 on the Husqvarna Factory bikes.
Seat base and Air Cleaner Cover – Plastic, much lighter than OEM
Tanks:
Two styles of tanks manufactured by LYTA in the UK. The later style was used on the 1972 Husqvarna Factory Bikes.
Early LYTA with Monza Flip Cap
Later LYTA with Screw-on Cap
Frame:
Profab Bolt-Together Frame – much lighter than OEM
Engine Rear Cradle
Under Engine FootPeg Bracket
Swingarm
Collect Much??:cheers:
Lots of sweet stuff there, you just get that profab swingarm?
One ust sold on ebay.
Thanks for posing that
Expansion Chamber / Pipe:
Numerous manufactures made pipes such as Bassani, Hooker, Torque, and others. Only ones in the shed were these two Hooker pipes.
Up Pipe
Down Pipe – for short track, TT, or flat track
Lors od aweet stuff there, you just get that profab swingarm?
Saw that swingarm on ebay - got me thinking, might need to start selling! Have a couple of different styles - seems Profab was continuing experimenting.
More Misc Items:
Air / Oil Fork Kit - GOKI was a popular brand. Much discussion at the time whether they helped or not - nice farkle though.
Air Filter Ring - When the OEM paper element was tossed, most used Filtron foam filters. This ring was used to ensure a good seal between filter and the OEM air bell.
Intakes:
In post #3 (w/ the Mikuni carb) is an adapter intake - no name
ACK - Letters cast on side of intake
Reed Valve - Another no name. Interesting that the reed cage/petals are from a Yamaha. Rather large opening - currently on a 400CR.
DH Enterprises made a reed valve for the 250.
Cycle Illustrated (October 1972) magazine has an interesting article on Boysen's early reed valve on a Husky.
