firebolter
2010 TE 310. Took off the rear tail extension (includes blinkers and tag light). Covered the wires in a bag and tapped them up and stuff them behind the brake light. Removed the front turn signals.
When I roll the key and start it up, brake light is on. Check the usual suspects:
1. Front brake micro switch, almost always the culprit. No change. Even unpluged it, still brake light on.
2. Checked rear brake, loosened the "cam: to allow the brake pedal to return all the way, no difference.
3. Check rear brake resv to make sure it is not too full causing master cyl to activate rear brake switch. No difference.
4. Check wires under headlight. All connected and nothing bare I can see.
So I guess it's down to tracing the wire from back to front.
For now, I just dis-connected it as this is a woods bike and I don't need the brake light.
Weird..................
