Welding covers.
speedyauto
Can the outer clutch cover of an auto be welded.:thinking:
I had a clutch spring break & this was the result :banghead: & now I've also had to make a spring cover.
:cheers:
I am sure it can be welded, You need to determine if the case is aluminum or magnesium and find a qualified welder accordingly
I would say yes, providing it's TIG welded, but you could also repair it yourself if you use Lumiweld or Techno Weld.
I looked into the Lumi & Techno weld products & spoke to a few welding specialists & they told me to steer clear of them, But on a positive they where able to TIG weld it quite cheaply:).
Good to see you've got it fixed.
Are you going to grind down the weld a little and repaint, or leave it as it is ?
I was told to leave it alone as smothing it out reduces the strength of the weld & on a cover that is already compromised for strength it wouldn't be wise, on a plus side even unpainted it's difficult to see when it's on the bike unless you are looking for it.
I will be painting it after I've ridden it to make sure there are no leaks.
Cheers.
