What Gearbox Oil For '75 175cc GP?
Binx
What gearbox oil is correct for the '75 - '76 Cross Country bikes? Thanks in advance. Binx
motomwo and wrx - someone just sent me an old spec sheet for the 1975 175cc Cross Country bike and it recommended SAE 20 for the gearbox. The Torco and the Spectro are 75 and 80 weight respectively. Big difference between 20 and 75/80? Is there a reason not to stick to the recommended 20 weight? You can tell I have no past experience with this bike or any vintage Husky for that matter. So I appreciate any insight you can provide. Binx
Attached Oil Viscosity Chart shows that 20W crankcase oil (green column) is the same weight (viscosity) as 75/80W gear oil (orange column).
Vinskord - the chart clears up the viscosity questions for me. Thanks for sending it.
I finally figured out how to search the archives on this site and discovered a bunch (no surprise) of oil threads. Got the impression that lots of knowledgeable owners of vintage left kickers were using ATF Type F in their gearboxes. That stuff is cheap and available. Any reason to not jump on the ATF bandwagon?
<<you will get 11 opinions!>>
Yeah, I knew I was opening a can of worms. Appreciate the link to the older thread and the caution regarding ATF. Will play it safe and go with Spectro, Torco, or similar. Thanks again, everyone.
DON'T USE ATF! I have tore down many, many Husky transmissions and just about every one of them that had atf in them had pitting on the drive faces on some of the gear teeth especially on the big bore motors such as the 390, 430 500's.
Most people go to the ATF to help prevent clutches from dragging. The synthetic gear oils made for wet clutches will help prevent this and protect the gears and bearings.
Marty
