What rear will fit?
tgrimmel
Hi,I have two 1982 Husky's 250 and 430 wr's. Both have 17 inch rear wheels. I wanted to replace then for a larger selection of rubber. What rear wheels will fit ? Thanks Tom
1983 & 84 18" wheels will fit, the date is stamped on the rim, so you can tell what year there off.
I had verified they came with 17" rears from the factory when I got a copy of a test that did both the 1982 250WR and the 250XC. Until I got that test copy I had thought a PO swapped them out as I had been under the impression WRs came with 18" rears but mostly in the 70,s and not until 1983 in the 80's
