What sockets/wrenches do you carry?
Guoseph
For trail-side repairs, not your home tool box.
Mostly interested in what size of fasteners are on an 08 TE250 (I assume 310, 450, and 510 are similar) to carry the correct set of tools. I have only gone through parts of the bike and 8/10/12mm bolts seem to be the most commonly used.
A few specific questions:
Do you carry any sockets/wrenches larger than 14mm and what is it used for?
What size spark plug socket do I need?
Is there any need for odd size sockets/wrenches : 9mm, 11mm, 13mm?
Any thing you might need two of because the bolt and nut are the same size?
Any weird or bike specific tools (other than the 12mm allen front axle) that's needed?
Thanks,
Alex
8, 9, 10, 11,12 end wrench and 1/4" sockets
1/4" driver and 3" extension
1/4" bit socket
15, 27 axle wrench
(I have Motorsportz front axle nut)
hex 2, 2.5, 3, 4, 5, 6 bits
screw driver
phillips driver
pliers
crescent wrench
spark plug wrench
chain press
tire irons 3
What do you use the 9mm and 11mm for?
Is the Motosportz front axle nut 15mm?
Any idea what size spark plug wrench I need?
Thanks,
Alex
Should have edited 9 out. Is wrench for other bikes. I also have 15,17,19 wrenches for kids bikes axles. The 11 is same as 7/16" and is needed for Motorsportz steering stabilizer.
Mousse tubes in front and rear safes me some spanners to remove wheels.
No air pump or tubes .. no levers.
I got one 280mm long Multigrip
little socket and bit set up to 13mm with allen up to 6mm.
8mm dep socket driver
one flat screwdriver .
Some m6/m8/m10 bolts and nyloc nuts.
5 fuses and 1m wire.
some liquid metal to fix holes in crankhousings.
thats about it.
I dont my bikes super reliable****************************************
Joking a venhill tool bag with an adjustable spanner patches n co2 inflator. And a soark plug justincase 2pop you see.
