andyman
Would someone be kind enough to tell me what size the hex hole in the front axle nut is on my 09 txc450? If I make one more trip to grainger or sears and come home with the wrong size, my head might explode.
I've got enough allen wrenches in my tool boxes to build a steel frame house... but none that fit this stupid nut.
I suppose it's an 11mm, but can't be certain. a 12 is too big, a 10 is too small, but two sixes fit in there just fine...
I've welded a nut that fit onto a bolt that had a 10mm hex head (old yz sprocket bolt/nut.... no workie, it twisted off. the two allens didn't work.... I'm at the end of my rope. It's out there soaking in aero-kroil right now. hammer and punch is tomorrow if I can't figure it out.
EDIT: I just looked at my brand new proto "12mm" hex head socket that I picked up from Grainger today agin... it doesn't fit b/c it's a "1/2" not a "12". IDIOTS!!! Actually, it's just as much my fault, I should've looked at it before I left, but I've never had a problem with them before. Tomorrow will make my 3rd trip to Grainger. Good times....
