where does this washer go? (te310)
bensl
i had this rubber washer drop on the ground when i pulled the inside clutch cover off from my 310. i cant see any reference to where i came from in the manual so not sure where it should go. does anyone know? im thinking maybe from the kickstarter somewhere?
any help would be appreciated.
cheers
Lookes like the washer that comes from the black head were the spark plug is.
I'm with you. it really does look just like it. Looks too out of round to be a bearing seal.
If its plastic I don't think there are any seals like that under the clutch.
They might have dropped it in the motor when they built it!
It does look like a seal off a shaft that exits the crank case. I dont know if there is anything like that on the cover that you removed?
thanks guys. i havent had a chance to get back to the shed but i think it might be the "Cylinder head cover Gasket". Maybe it dropped in there when i took the head off??
