Where to buy Valve Shims
F1000
Where is the best place to get valve shims for the 2013 TE449?
Head Gasket?
Valves?
How reliable are the valves over time?
Thanks
Glenn
If you've already checked and you know you need them. I've bought at the Yamaha/Honda dealer. If you want to buy a complete set you can buy them from Hot Cams. I have also found used sets locally on CL. I would just check and figure out what you need BEFORE buying. Also bring the same mic you used at home to the shop. The valves are never perfectly what they say. ALWAYS check before you buy. . . DTDT
Joe
My Bad, yes the 449/511 are different so disregard the part about going to a Honda/Yamaha dealer but the process is the same from looking at manual. You may need a trip to the dealer if you find you need replacements
Yes they are different. My dealer is a drive away, not one I will be doing. Sounds like it is a dealer purchase item only then.
You can get them through a Beemer dealer if they stock them and its a convenient location. If no just order through BMP. Theyll take care of you
If you are lucky like I am your local dealer will have an assortment of used shims. Measure yours, work out how much bigger/smaller you need to go. Then you can head to the dealer and they might swap you your existing one ones for the correct size spares. I got mine for $10 each, I dont think it is justified to spend the $ on a full shim kit unless youre running a shop.
