Who needs that sinkiung starter!
need2boat
So I'm waiting on a new Sprang as the starters still hanging from time to time. I know many a person has removed the starters from the TXC/TE 250-310. So my question is:
What about the needle bearing (42) the starter pinion (32) rides in. The bearing is pressed into the left side case and I'm concerned without something in the center the bearings might work themselves loose and cause issues. I do plan to put the starter back and this was just a stop gap so I could maybe race this weekend that said it's not worth blowing the motor over a needle baring.
SO others that have pulled the starter? did you pulls the needle bearing as well?
