Will a 79 WR250 Engine fit in an 83 WR250 Frame
dnietsche
I have an 83 engine that has a ton of mag corrosion nd i have the oppertunity to buy a 79 250 for very low money. Will the 79 fit in the 83?
No, it wont fit, different cases. From 82' on the swingarm attachement bolt goes through the engine case.
Using the 79 rear mounts off of the 79 frame will work . You may need to rework your 83 pipe a little .
I kind of doubt it will work for the white 83 frame. A silver 82 frame like the one in my avatar will work with the 360 engine and the mount as mentioned in post 3 above. It looked like that squashed section of frame near the shifter on the silver frame would be necessary. When I had the 360 engine in that chasis a 430 pipe for that frame worked fine for my purposes. Sorry I can't be more specific without experimenting.
Fran
