workaround for the Husky xlite factory clutch tool
need2boat
Just wondering if the collective have found a good tool to use to hold the clutch basket when torquing it down. The factory tool is basically a adjustable spanner wrench that runs around 80.00
Last time I marked the nut and used a cordless impact gun. Worked find but figured I'd see what others have used. The motion pro clutch tool doesn't open wide enough to fit across the mouth of the clutch basket.
Joe
Take two old steel plates and weld a 10" rod between them so they will fit between the basket openings. This will hold the basket and the hub when removing or installing the clutch inner hub. I have used this method for about 45 years now and it works great.
Paw Paw
Any chance I could get a picture. Are you making a Y with the 10" pieces and just welding and bar across it?
