Wr250 clutch cover repair???
jcbr6
I have a WR250 that has damage on the clutch cover from the kick starter. I bought the bike this way and it has a tendency to kick back hard on shutoff ( i think that is what did the damage)
anyone else have a similar issue?
Has anyone tried to repair these covers?
By the look of the frame gusset in your photo I'm guessing you have a 73 - 74 MK frame 250wr. The clutch cover is most likely aluminum so yes the damage can be repaired. You'll just need to find a tig welder. If your clutch cover is not aluminum then it will be magnesium. 73-74 was the time when Husky began changing engine cases like the ignition and chain covers from alum to mag. I don't know if this also included clutch covers. There are many good covers on Ebay. All clutch covers from the 1972 MJ frame to the 1974 MK frame era will fit with the exception of the 74 250 mag and all the 125's & 175's.
Offhand I don't know what would cause your motor to kick back when its shutdown, Kickback is typically a starting problem. I would start with checking the timing, getting a new kill switch. If you're having other issues while its running that could provide a clue as well.
