Valve check and exhaust just tight and intake 2x spec. I want to adjust to high end of spec.
Is it possible to get enough cam chain slack so i can remove cams to get to shims without completely removing can chain tensioner?
I assume I must remove cams completely to replace shims.
If I must remove tensioner, sub-tank does not allow enough clearance.
How the heck do you remove sub-tank? I have it loosened but I can't get enough clearance between the motor and the frame tab where the motor mount bolts.
Advice?
Thanks!
Advice?
Thanks!
