X-Lite kick starter shaft be discontinued
4stroker
My TC 250 2010 has the kick starter shaft broken for second time and the dealer says it be discontinued.
I think it's dificult to made a new one.
Any ideas? Electric starter is not a option... ☺
A friend of mine had the same problem and he bought the kick starter shaft and the kick pedal from 2014 model. They fit correct and since then he did not have a problem.
You have to buy and the kick pedal and the screw for it, because yours does not fit to the 2014 model shaft.
Hope to help you.
Friend with a '13 TC250 has broken 2 and the last replacement was an updated one. New one looks better and has held up. Check with Hall's.
1) Do not kick your bike over as if it is a 2t bike. A slow push-down through the complete kicker-stroke ending against the footpeg is what my bikes want.
2) If the kicker feels like it is locked at TDC, do not force the kick over. Tap it off the top and get TDC on another stroke.
Good luck with the bike.
New part number is 8540193. I have two 2013 TC 250's and updated both. Beware if it is very hard to kick, the auto decompression release may be stuck. If so, remove the valve cover and push it back into position. I did this and it never happened again, knock on wood.
Wait, that might be the old part number!!! Part number on the part bag I got was 8539429
