Well I replaced the spun flywheel with a new woodruff key and the bike runs SUPER, and what's more the e-start worked perfectly all day.
The off idle studder is gone and the motor actually has power now.
What's more, the spare motor I disassembled had a folded over key as well.
This is my theory.......the flywheel slips, advancing the IGN timing which at low rpm makes it not only hard to start but as the motor heats up the ECU advances the IGN timing more until there is too much advance to push the motor past TDC with the starter. Eventually, it gets so advanced the motor starts kicking back and might even crack the case at the worm gear pilot hole like my spare motor has.
When I changed the TPS setting, it most likely retarded the IGN timing as well making it a bit easier to start as well as emilinated the off idle studder for a while, but it was not a long term solution.
Now that the flywheel is on correct the timing is correct and the e-start works hot or cold.
If you are having hot start problems check the flywheel for proper orientation.
