'04 TE450 running rough, backfiring
Hoosq fan
Took carb apart including TPS off, put back together, starts ok but try to rev it and I get clouds of black smoke with backfiring out through the muffler as I open up the throttle. Could it be the throttle position sensor got altered? If so, how do you set it. What does it do anyway?
Great question... and I do not know the answer. Hopefully someone else will give their input.
Welcome :cheers:
The TPS retards the timing at low speed. I don't think that is your problem I have disconnected mine and couldn't tell much difference.
Have you checked your valves lately?
Did this motor run correctly before you tore that carb apart? If the pilot circuit isn't perfectly clean your bike will run terribly, if at all...throwing flames out the exhaust, sputtering, won't idle etc. Is the choke system in tank? If you're carb is absolutely perfect and you know it, then its likely really tight valves.
