125-200cc 06 Wr125 Redo - Done
Discussion in '2 Stroke' started by dartyppyt, Nov 28, 2010.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Should be some good stuff coming from this weekend!
  2. mike328 Husqvarna
    colorado
    Graet Job...I like the play by play narrative with photos.
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thought I'd do a little bling stuff this weekend on getting the triple clamps cleaned up, polished and reassembled.
    Pic 321 I will be installing a new polishing wheel on my wire wheel-polisher. You can purchase packages of polishing compounds that you apply to buffing wheels. I use a dark red product, modtly called "Tripoli".
    Also you will need a round file (Chainsaw sharpening file) and 1/2 round file.
    Pic 322 Is an old grinder that I converted exclusively for a wire wheel and a polisher. I mounted it on a moveable stand. To the left is the wire wheel and to the right is the new buffing wheel installed.
    Pic 323/324 Using a 1/2 round file and the small round one. I am going to file off all the visible casting marks that you can see. I don't worry about any that are behind the number plate and etc.... that are hidden. I file these flush with the surrounding aluminum surfaces.
    Pic 325 After I have filed all the visible casting marks off. I wire wheel the whole triple clamp to get rid of any blemishes on the aluminum from years of crud.
    Continued-
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 326/327 I use an electric 5" orbital sander to sand the aluminum. I use 12o grit discs to remove the file marks and to remove any marks from year of dings and then final sand with 220 grit disks. Be careful not to go crazy with the sander and remove the thickness of the aluminum. You also don't want to destroy the strength/ integrity of the thickness of the clamps.
    Pic 328 You will have to do some hand sanding to get into the hard to reach areas.
    Pic 329 I wanted to show you the top clamp where a grinder was used to grind the aluminum away to clear a steering stabilizer mount. I want to file and sand the marks out to clean them up.
    Pic 330 After you sand the triple clamps in 220 grit paper. I will be final wet sanding them with 600 grit , silicone wet/dry paper along with using a solution of water and dishwashing soap.
    Don't ever, never, notta, sand inside of the tubes, in the pinch clamps, that hold the fork tubes.
    Continued-
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 331 I take my time and wet sand all the aluminum on the triple clamps. I want to remove any prior scratches and blemishes.
    Pic 332 I apply Tripoli compound to my buffing wheel.
    Pic 333 Polish all the aluminum on your triple clamps. I keep the wheel loaded with Tripoli compound often.
    Pic 334 Final hand polish your clamps and all the can't reach areas. I use a liquid product called "Green Dragon".
    Pic 335 Next I am going to install the seal, spacer and bearing on my lower triple clamp. I have to use my press to get the bearing on. So that I don't damage my new bearing. I simply cut a long piece of 1" PVC pipe to press the bearing on. It is usually the same size as the bearing race and also is cheap. I put all the hammers away! Only use a press a little at a time.
    Continued-
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 336 I cleaned out the top and bottom steering tube areas to install the new bearing cups. I sanded the areas lightly and also sprayed some WD 40 in them so that the new bearing cups are easier to press in. I took one of the old bearing cups and cut a notch in it so I could use this along with a flat piece of steel to press the new cups in. Afterwards, with cutting the slot in it. I could just pop it out with my finger. I also put the hammers away on this one, as well, so you don't mess up an expensive set of steering bearings.
    Pic 037/038 Shows the triple clamps greased, reassembled and the sure look sharp! I also found a BRP mount in the box of extra parts included with the bike. I put those on so we can get a set of those Trail Tech Fat Bars (1 1/8") that Kelly recommended. I will come back later once the forks and wheel are installed to adjust the (side to side) steering play in the new bearings.
    If it wasn't for those deep grinding marks I encountered on the top triple clamp. I could of had these done in a couple of hours. I spent alot of time filing them out and reshaping the aluminum so it looked like a stock piece.
    Pic 039 Sorry that I didn't get a little further. I wanted to get the swing arm polished and back on, as well. I sold my son's 04 RM 125 and had to just final clean it and crate it up (What a pain). It is going to a new home in Colorado. But this is also the 06 Husky fund! To top it all off, we had a nice blizzard today!
    The old 04 RM still looks looks pretty good!
    Thanx!
    More to come next weekend!
  7. wallybean Mini-Sponsor
    Montana
    Darin,
    This is awsome stuff as always. I can see myself going through this process later this winter for my WR 360. It is feeling like the redheaded step child right now and you never want a sullen 360 on a ride. :D The WR 125/144/167 will have to wait until next year as I can't have it not available for those moments when it is rideable.
  8. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    The old Rm looks real good - Mr Polish it!:thumbsup:
    Good work - makes me realise I shouldnt even attempt to do this stuff
    Your a good dad
    Pics of my old 06 when it was like new
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx Gang! Also glad you posted some pics on the 06, I can use to reference stuff. I forgot about those WR125 decals on the swingarm.
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 5 Now, I am moving on to get the forks done. Had a small dilema, Ace did the suspension years ago but are no longer in business. Thanx to Bottones (Husky Dealer), they were able to give me an approx fork oil level height (120mm) and also recommended, I go with 5 wt oil. Les was very helpful @ LTR as well. I went ahead and changed the oil and cleaned the seals. I have to come back anyways to set Evan's sag with him on it all geared up.
    Sorry but for some reason, I lost some pictures. Using my fine wire wheel mounted on my floor grinder and polisher. I lightly removed all the anodizing off the tubes. It was faded, corroded and anything was better than what was on there. I also wanted them updated in color. I final sanded them with 400 grit sand paper. I took great care not to remove any aluminium off the tubes. I also removed that brown/gray anodizing on the feet.
    Pic 006 I sprayed my fork tubes in SEM black self etching primer. Same stuff I showed you in the frame painting section. They looked so darn good that I decided not to spray them with black enamel. So I stayed with the SEM black primer on them. It is actually tough and durable. If I have issues with it then I can reprime them or get them black anodized.
    Pic 008 I decided to move on to get the engine cases ready for painting while the forks were drying. Using a razor blade. I removed all the gasket material.
    Pic 009 Using a scratch pad. I polished/cleaned the gasket surfaces.
    Pic 010 Using a tooth brush and engine cleaner. I removed all dirt and years of grunge. You want all dirt and grease removed.
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 011/012 I used a small screwdriver and rag to clean all the tight nooks and crannys.
    Pic 013 Using Lacquer Thinner and a rag, I wiped down all the existing case paint and gasket areas that I will mask off.
    Pic 014 I used Blue Painters Tape and trimmed the edges using a razor Exacto Knife.
    Pic 016 My forks are dry so I decided to take a break and slide them into the triple clamps.
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 017 I just received my new new Moose Swing Arm Bearing Kit. I had to use my floor press to get the old bearings out.
    Pic 018 Once the bearings were removed. I cleaned the corrosion out of the holes with 220 grit sandpaper.
    Pic 020 To press the new bearings in. I will use a large C clamp, 16mm socket and some WD 40 (To help the new bearings slide in). I don't use grease because it can get in between the bearings when pressing and keep them from bottoming out.
    Pic 021/022 At first press the inner retainer in the swingarm from the kit. You should always do one side at a time, both new and old so you have a re-assemble reference.
    Blakelpd5 likes this.
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 023 I sprayed WD 40 into the hole and also on the bearing side to help pressing the bearings in.
    Pic 001 Using the C clamp and an extra retainer that was in the kit. I started pressing the new bearing in. Make sure the bearing starts square and is in line with the hole. If not you'll damge the new bearing. This is my I like using a C clamp because I can go a little at a time.
    Pic 002 Keep pressing the bearing till it is flush with the swingarm.
    Pic 003/004 Next I use a 16mm socket to press the bearing down the rest of the way, until it bottoms out on the inner retainer that I previously installed.
  14. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 005 Press the next bearing in until it stops against the one you previously installed.
    Pic 006 Using a hammer/16mm socket. I used a light tap to install the seal.
    Pic 007 Pack your new bearings with grease and install your bushing.
    Pic008 I use zip ties so nothing falls apart until I install my swingarm down the road.
    Pic 010 Next I moved on to file the cleets on the foot pegs. They were rounded over from wear. I just want some better bite in them to grip the bike. I wired wheeled/sanded them to remove any chipped/worn paint/rust. These will get a new nice silver paint job.
  15. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 011 I wire wheeled the end of my axles and the swingarm bolt. they will get a new silver paint job on the ends. I want to be able to hit these, the foot pegs while doing the engine cases.
    Pic 012 Next I primed the foot pegs and axle ends.
    Pic 013 Now I am moving back to final sand and prepp my the engine cases. I want to get rid of all the discoloration, chips and etc..... I use 220 grit sand paper on all the old silver finish.
    Pic 014 Next I use a scratch pad to scuff all areas again and also the tight areas. I also use Wax/Grease remover (Duplicolor) and wipe down the finish. I do not want my primer or finish to lift/fisheye because of old grease/oil.
    Pic 015 Next Using the SEM self etching primer. I primed the cases.
  16. rockdancer Husqvarna
    This is really useful - its looking really good too. Great work.
    How do you keep all the parts organised when bikes apart ?
  17. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 016 Mix your paint according to the directions on your can and do all the stepd I did previously as in the frame painting segment. You now want to wipe all surfaces down that you'll be painting with a tack rag.
    Pic 017 Paint your pegs, axle ends, and engine cases. On the foot pegs and cases. I sprayed one cover coat, one medium coat and one final mist coat.
  18. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 018/19/20/21/22 Everything sure looks good. Wish it would last like that forever!
  19. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 023 While the engine cases are drying. I ran a tap thru all the frame threads to remove paint. You also have to remove the paint on the inside of the swingarm axle bolt hole and shock linkage bolt hole.
    Pic 024 I remove the paint on the coil bracket tabs so the cole can ground against frame.
    Pic 001/002/003 Shows the engine cases all painted up and the tape removed. Wallah! Looking good!
  20. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Pic 004 Though I'd show you where I am with frame assembly.
    Nice to start seeing some results after putting the stuff back on.
    Thanx!
    Hope you enjoy these!
    Darin
