08 SMR510 popping sputtering mid throttle
Discussion in 'EFI/carb' started by Tepco, Jul 6, 2012.
  1. Tepco Husqvarna
    Greensboro, NC
    2008 SM510R
    NT650, XR100, CR85SM
    Great, have to find a lambda sensor now!
    Thanks for the clarification.
  2. dave35 Husqvarna
    london
    could be a bad fuel map, u map need to dyno tune it with ibeat or load differant map,
    last time i trimed my base map (00) using a autotune i had a big mid range misfire when driven hard
  3. Tepco Husqvarna
    Greensboro, NC
    2008 SM510R
    Ok, I'm getting somewhere. I now have an iBeat and have set the TPS but cant set the FB without an o2 sensor. I mounted the JD on the bars to see where it was stumbling (because it still was after the TPS adjustment) and it was in yellow mode 2. I had to adjust it to 1 to get it to run right. The FB1 is set at 102-100-100 and I have read that 97-100-100 are the numbers. I set the TPS by getting the wot to 100.2% then excepting the tps mv which was 1001.
    I am 90% there and need an o2 sensor to finish it, if anyone has one they would like to sell please let me know.
  4. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    Give us a call if i can find an extra one its yours free. 503-585-1153
  5. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    3 cheers for Bill and good thoughts go out to Tepco on getting close to solving his problem!
  6. Tepco Husqvarna
    Greensboro, NC
    2008 SM510R
    WOW, that was insane fast shipping! Got it today, will be hooking it up and adjusting this evening.
    Huge thanks Bill!
  7. BILLF CH Sponsor
    North Carolina isnt that far hope it works.
  8. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Now you know why I buy all my Husky parts from Bill and Bryon
  9. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Lookin' for an update.......
  10. MorrisBetter Husqvarna
    Nor Cal
    TE501s
    BMW R1200GS
    So what was the fix?
  11. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Bumping, for the fix, or an update, also, what fuel filter did you end up putting into this bike?
  12. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    I guess he got it fixed, this from SMJ:
