250-500cc 09 WR300 6 speed conversion
Discussion in '2 Stroke' started by Rob578, Jan 22, 2012.
  1. Rob578 Husqvarna
    Atlanta GA was CA
    Beta 300RR Beta 500RS TE 630
    Honda 919 sold FJR1300 sold
    I'm still having problems fitting the tensioner, the arm hits the pawl rather than the roller. Maybe a pic would help. DSC01026.JPG DSC01027.JPG
  2. wallybean Mini-Sponsor
    Montana
    Rob,
    Is that the top for the 6 speed shift drum or off the 5 speed? Same question for the detent arm?
  3. Rob578 Husqvarna
    Atlanta GA was CA
    it's all from the 6 speed. Looks like I need to space it out and use the spring from the 5 speed. I don't see anyway to use the 6 speed spring. The diameter of the case casting is too large for the 6 speed spring to slide over.
    I did use the 6 speed bearing which is wider but I don't think that's the problem, the shifter works just fine.
    If there's any interest in anyone doing this in the future I'll take the parts fiche and highlight all the parts you need to procure, including the gaskets and seals you need to replace
    Blair7 likes this.
  4. Fat Tire Flyer Husqvarna
    Canada
    Yes please.. I bought a 6 speed 360 bottom end a couple years ago to install into my 2007 WR250.. But I've been too busy to do the install..
    Also although I am a little nervous about the install (I am a bicycle mechanic by trade).. I am more worried about any extra parts I will need
    or suggested to replace and I did not order before starting (gaskets, bearings, seals etc).. Also any special tools I will need to do the install
    and do not have (pullers, extractors etc).. Nothing worse than taking something apart and then find out that you need a new part and/or a
    special tool to proceed.. Thanks in advance.. Cheers.. :)
  5. Xcuvator Husqvarna
    Scholls Oregon
    yes
    When I was setting up mine I called Halls and was told the shaft end clearances should be between .0015" and .025". One of the reasons I wanted to know is that my 5 speed shafts had .020" and .025" clearance when I took it apart and it seemed a bit much. I wanted to tighten up the 6 speed to the lower end of the spec, but because of what shims were available, I ended up around .020+".
    It shifts and works really good.
  6. Xcuvator Husqvarna
    Scholls Oregon
    yes
    The arm in the picture is a 5 speed arm. The six speed has the roller on the other side, so it is on the outside.
  7. Rob578 Husqvarna
    Atlanta GA was CA
    I just looked at the parts fiche, I don't think I have the right arm. Funny thing is the fiche shows the roller on the outside with the curved part of the arm up. Both of these are opposite. I'll post the fiche when i get to the office.
    One thing i should mention is that i didn't buy a complete bottom end. All I could find was the shafts, shifter drum, forks and tensioner. So there's a good chance I have a tensioner for another transmission.
    6 speed on the left
    5 speed on the right
  8. Rob578 Husqvarna
    Atlanta GA was CA
    Here are the parts fiche for the 360 and 300
  9. hammer Husqvarna
    You will be an old man before you get it done. Bring it over to my shop and we will do it together no charge.
  10. Rob578 Husqvarna
    Atlanta GA was CA
    I'd jump all over that offer.
  11. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Rob, when you get the right arm, your problem should be solved.
    You might take a close look at your shift shaft spring. If the coils don't line up, it can cause those related parts to bind.
  12. Fat Tire Flyer Husqvarna
    Canada
    Thanks Armin.. But I am just way to busy with things.. Last year I didn't even get a chance to get to the Ganaraska (not even once).. Mostly dual sported more locally with the wife..
    I promised the guys I will be at the Ganny this year.. And I would much rather ride than wrench.. So realistically it will be next winter (or later) before I will do the 6 speed install..
    And by then yes I will be an old man.. Because I will be turning 50 in August.. :oldman:
  13. Rob578 Husqvarna
    Atlanta GA was CA
    Don't feel bad, I didn't get around to it until I was 53
  14. Rob578 Husqvarna
    Atlanta GA was CA
    Realistically if you have the motor out, knew what you were doing. You could do this in an afternoon
  15. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    Man if someone came up with a reliable service for doing this I am thinking they would make bank. I am constantl hearing people turned away from the 250/300 for lack of 6 gears. If there was a shop doing it would probably be backlogged gawd knows how long. I know I would pay good money to have it done.
  16. TROFFER88 Husqvarna
    Camas Wa
    I have my six speed sitting here in a box , trying to decide if I should try to do it or just have a real mechanic do it
  17. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Not sure why people need a 6 speed on the 300cc engine. My bike has plenty of the right ratio for really tight trails to open desert. I used to own a six speed KTM EXC250, and the 300 is not for want of anything in any situation that I can put it in.
  18. Rob578 Husqvarna
    Atlanta GA was CA
    I hate losing top end drag races to yz250s and 4t 450s. The 5 speed runs out steam pretty quick.
    Actually I have a tag on mine and a 2t is a blast on these AMA dual sport rides, so much in fact a couple of the snobbier clubs even ban 2ts from their rides.
    Besides, at 53 I'd rather exercise my brain with a Project like this rather than doing crosswords on the Metro
    Al H and Dirtdame like this.
  19. Rob578 Husqvarna
    Atlanta GA was CA
    It's turning into a pricey mod. The good deals on eBay aren't there anymore, I paid about $300 for the transmission, the bottom end gaskets, seals and main bearings were $150 and the top end parts are probably going to be at least $175
    Also if you check a lot of the 6 speed parts are no longer available from Husky.
    If you are considering doing this I would jump on it now, it's not going to get better
  20. Rob578 Husqvarna
    Atlanta GA was CA
    FINISHED !!
    And it runs
    Full report coming up as soon as I can get out
    First impressions riding around the 'hood.... With 15/52 easy cruise at 60mpH and will loft the front wheel with a throttle blip in first.
