12 Hole Injector Upgrade For Te250 / Te310
Discussion in 'EFI/carb' started by Ex HVUK, Aug 4, 2011.
  1. Coffee CH Owner
    Much thanks for the update Jason. :cheers:
  2. goxu1 Husqvarna
    Australia
    TE310
    Yamaha AT3-E
    Hi All
    first post here. I just bought a new 2012 TE310. It has the upgraded ECU and injector. Not sure what else the dealer did before delivery.
    I haven't had a chance to give it a decent ride yet , but was mucking around at the end of my street over the weekend and noticed that when
    slowing down to do a U-turn , the revs increased rather dramatically.
    Has anyone else noticed this ? I thought that it would be a pain in the A on trails if this happened all the time.
    Paul
  3. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    Maybe throttle cable or TPS needs minor adj.
    Is it doing it in the turn or just slowing down
  4. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    Interesting. My idle changes about 200rpm depending whether the bike is on the side stand or standing vertical.
  5. goxu1 Husqvarna
    Australia
    TE310
    Yamaha AT3-E
    Seems to be only doing it in the turn. I rang a local husky dealer and he said it was to counteract the bike dying out at low revs ,
    but it doesn't seem right to me. I was going to get the bike registered and could see it becoming a bit dangerous on the road.
  6. glangston Husqvarna
    2012 BETA 350 RS
    Mine never did it...not stock, not powered up. Did up idle to 2000-2100 for best performance.
  7. Freaky Husqvarna
    Kidderminster Worcestershire UK
    2010 TE250 x-lite Race ECU/Injector
    The throttle cable is routed wrong somewhere, as you turn the bars the cable is being pulled hence the rise in revs.
    AndrewS likes this.
  8. Aaron8 Husqvarna
    This sounds correct. Do a static test. With the engine running, turn the bars left and right.
    BTW, try to talk to the mechanic at your dealer, not the :censored: sales guy.
  9. Aaron8 Husqvarna
    OK this is weird. Does the idle change if you lean the bike a like amount to the right side?
  10. goxu1 Husqvarna
    Australia
    TE310
    Yamaha AT3-E
    Will check this arvo. Some good thinking here. Maybe the cable is getting caught somewhere.
  11. goxu1 Husqvarna
    Australia
    TE310
    Yamaha AT3-E
    yep , cable getting jammed somewhere...thanks all
    Freaky likes this.
  12. Coffee CH Owner
    Thanks for letting us know what your issue was. :cheers:
  13. goxu1 Husqvarna
    Australia
    TE310
    Yamaha AT3-E
    So many damn cables and other stuff up at the front end. No wonder its getting jammed up.
    Oh , the joys of modern bikes..
    Mike-AK likes this.
  14. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    I bet I could get rid of half the wires via common grounds and placing relays up front behind the headlight. Oh...and Vegemite and its bastard brother Marmite are just plain nasty. :eek:
  15. goxu1 Husqvarna
    Australia
    TE310
    Yamaha AT3-E
    Ahh come on , vegemite is not that bad.
  16. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    I suppose one might get used to it, but after that if the verdict is "not that bad", i.e., not that good either, why bother?
  17. goxu1 Husqvarna
    Australia
    TE310
    Yamaha AT3-E
    the key is to use it in moderation.
  18. Moesgaard Husqvarna
    Skaerbaek, Denmark
    TE310 2011
    Kawi kx250f '12, Montesa 4rt '05
    My 2011 TE310 has got an upgraded nozzle, ecu and leo vinci exhaust, but since I got som problems with it (won't rew or pull away) I took the gas tank/fuel pump and intake body apart. the injector nozzle is blue with only 10 holes!! what is this?
    Have anyone in here bought a 12 hole nozzle only, either from husqvarna or the kawa nozzle. If so what part number to look for and/or the cheapest on-line place to buy?
    regards Peter
  19. Aaron8 Husqvarna
    See this for 12 port Mikuni injector P/N and pics.
    I think the Kawi injector is 10 hole.
    http://www.cafehusky.com/threads/20...r-and-ecu-update-with-pics.24074/#post-228945
  20. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    any problem is easily solved if you just buy the OEM upgrade kit (which is a 2012 TXC310 ECU and injector), instead of trying to find a home grown (Kawasaki) solution. Does anyone even know if the KAW injector has the same size orifaces, same injector solenoid spec...
    The factory released a boxed set 12port injector and ECU mapped to TXC spec. I installed this package onto my 2011 TE310 and the thing works great. (I do not run the "open" exhaust, its got the dB-S/A cap installed and the thing runs great with great clean curve power)
    Buster714 and DG Harv Serv like this.
