126,875mph. Stock Production 1983 500XC
Discussion in 'Vintage/Left Kickers' started by husqyhamm, Oct 16, 2016.
  1. Bigbill Husqvarna
    '83 250wr
    0 right now
    I'm going to use maxima 727 at 20:1 mix and jet for it. That's more oil/ lubricate over the 40:1 super maxima I was using.
  2. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    best get a 44 gallon drum bill, at your throttle openings, you'll be out of gas in a flash:thumbsup:
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    so the manual is wrong when it specs 25:1 with 70s-80s technology oil?
  4. Bigbill Husqvarna
    '83 250wr
    0 right now
    Maxima spec sheet recommends 20:1 ratio for road racing and drag racing 2T I'm thinking for heavy duty use.
  5. justintendo klotz super techniplate junkie
    road racing yes...didnt you make it a point several times saying you are putting around with your grandkids? you have to match it to your rpm. in this thread, trying set a top speed then more oil is appropriate...are you going to abuse your swedes that hard? road racing??
  6. husqyhamm Husqvarna
    South Africa
    Quite a few 83-86 500 2Ts and 4Ts
    84 R80 GS Dakar; Victory 106.
    http://www.habot.co.za
    Local company which blends specialised synthetic oils for a variety of purposes.
    At 20to1 and 25to1 there is plenty drool and splattering.
    Normal riding with 32to1 no splooge.
    The ratio debate will rage forever and each to his own.
    I just know from experience what works best on my huskies for a variety of applications ranging from clambering mountains and ravines thru vmx to flattracking to roadracing and topend runs.
  7. husqyhamm Husqvarna
    South Africa
    Assembled , pressure tested.
    Some changes to previous spec.Testing in May
    oldbikedude likes this.
  8. oldbikedude Husqvarna
    Honey Brook Pa.
    Sweet engine, awesome siloete behind it.
    husqyhamm likes this.
  9. oldbikedude Husqvarna
    Honey Brook Pa.
    Just look at how tall the top end is on that motor. It's no wonder they vibrate.
  10. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    Is that a spacer behind intake?
    What's under the car cover, GT or Gt-40?
  11. Rowan Husqvarna
    Christchurch New Zealand
    87 430 auto
    It won't be a GT40 - I don't think he's that rich.
  12. 87husky500xc Husqvarna
    Dayton NV
    2020 tx300i and a few vintage bikes
    77 honda xr-75..
    Those 83 500s were a rough ride. My Xc vibrated like a damn jackhammer compared to my lc 500
  13. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    due to a much heavier piston
  14. 86 400 XC Husqvarna
    Calgary
    more Huskys
    82 to 87 use the same pistons
  15. husqyhamm Husqvarna
    South Africa
    Mossbarger reedblock.
    Mahle piston on lc had larger cutaway across transfer port area thus a tad ljghter. The lc crank webs had a slightly deeper cutaway to compensate for balancing.
    Biggest vibration factor is runout between crankpins.
    http://www.cav.co.za/pages/GT.html
    Under the cover is an animal of a different topic.
    ajcmbrown, 2premo and justintendo like this.
  16. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    just saw one of the only 3 original gt 40 open top 289 ci cars left in the world ( 1 is a dubious claim) at the historics. they took 5 opens and 5 closed cars in the first attempt at Le Mans. the 5 opens were slower and colder so they ran the closed cars, using the open tops at the mille miglia later that year. this car turned up as a wreck after being stored for many years. the owner had no idea what the significance of the car was. he does now. it was quick and I just assumed 6 litre but it was only a small block. very nice...
    2premo and husqyhamm like this.
  17. 86 400 XC Husqvarna
    Calgary
    more Huskys
    Well Rowan looks like i was right. :popcorn:
    husqyhamm and justintendo like this.
  18. Rowan Husqvarna
    87 430 auto
    What I was meaning is that it won't be an original GT40.
    Many years ago I was told by the (then) Husky importer for NZ to use air cooled pistons in my auto if I ever needed to replace one. He said the AC items didn't have cut-outs on either side so the gudgeon pin went all the way across the piston and had mode 'bearing surface'. Sure enough mine (LC) elongated the pin holes after a couple of years but the replacement AC item went for another couple of decades.
    Did the 500 have two similar designs over the years?
  19. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    Apparently , so I read , there were only seven Ford GT 40's made and one is in Melbourne.
  20. 86 400 XC Husqvarna
    Calgary
    more Huskys
    More than that, there is 2 real 1s here in my home town.
    1 is Dan Gurney's old car with bubble in the top part of the door for his head.
