'13 TXC starter/drive/flywheel woes..again
Discussion in '4 Stroke' started by guscycle, Jan 17, 2015.
  1. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    G-G still is not out of the red zone for finances, see Enduro21 for the latest press release from the CEO of G-G.
  2. Motosportz CH Sponsor
    thats not good.
  3. guscycle Husqvarna
    Florida
    '99 Husky CR250, '07 Husky WR125,
    '10 Husky SMR450, '98 Husky Scooter
    This appears to be the fix - no worm gear drive as shown on the new motor 250/340...now sell a affordable upgrade kit...especially with that bad ass billet MOTOR.jpg
    juicypips and joedirt like this.
  4. joedirt Husqvarna
    PA
    wr250
    where did you find that?
  5. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    It also has an oil gallery up the left side losing the external right side feed.
  6. davids70 Husqvarna
    Canary Islands, Spain
    TE 310 2012 - Nuda 900 2013
    I didn't know about that ... no good, let's see if they can move forward ...
    Starter and cover look different ... do you think an upgrade kit can fit ... ¿?
    guscycle likes this.
  7. guscycle Husqvarna
    Florida
    ..probably not...wishfull thinking
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    No but i see an engine missing a bike in the above post.
  9. guscycle Husqvarna
    Florida
    ..I believe it was on SWM's Facebook..Other side of motor..well the MX 250 motor
  10. guscycle Husqvarna
    Florida
    Got a hold of a almost new flywheel from a 2014 TXC 310 and compared to the original- WHOA! what a difference! New flywheel appears to have some type of hardening process (dark coloration), no deep grooves in freewheel contact area and when I measured the inner diameter of both, the original was .25mm /.009" wider! I can't wait to install the new flywheel! newfly1.JPG newfly2.JPG flyold.JPG
  11. ray_ray Mini-Sponsor
    The Philippines
    Good work there young man and so much for that jargon that was so prevalent in the bwm yrs about bwm making the quality better on the bikes that they assumed responsibility on.
  12. guscycle Husqvarna
    Florida
    Pretty darn happy there,Skippy! But look here,I am a die hard Husky fan(ain't climbed on the orange bus,tho)..I've owned nothing but Husky's for 41 years,raced 32 years on them, and honestly can swear on a bible and say I have only 3 mechanical let downs by product failure...once on my '82 WR250 after 3 years of use ,the moto plat died ,once on my '86 WR 250 ,which had forks that just wouldn't work, BUT Husky had come up with a fix,at no charge to it's customers,for replacement cartridges and of course now with my'13 TXC 310(which may have been avoided if the dealer did their job originally and therefore any other issues that were known about the early vin numbers - thank goodness Bob from Central Jersey Cycles has made every effort to make this painful problem less costly). After all this,I "intend" to race in a couple enduros,if my knees hold out, but it won't be on the TXC310, it will be my trusty,light weight,easy kick start '07 WR125! Here's my bikes ready for battle -'10 TC250,'07 WR 125, '13 TXC310 1.JPG
  13. beck Husqvarna
    2013 TE310R // 2014 Terra 650
    My process to turn my TE310R into a TC310R is underway.
    Remove starter - Check
    Remove canister - Check
    Remap of ECU by ZipTy - Check
    Remove O2 sensor - Check
    To Do
    12 Port injector - need to find
    Other things to make it lighter and more me happy - unknown.
    First seat time with no starter, feels good. I cant tell if its better or not. I was happy that after flushing all fluids and cold starting after sitting for 3 weeks, 1 kick = start!
    ray_ray, guscycle and Norman Foley like this.
  14. Boogie Husqvarna
    Australia
    Red head
    The 12 port fix is not required on the 2013/14.
    Can loose a 1kg with a new muffler.
    Keeping the battery? Another 1kg saving with lithium.
    guscycle and LandofMotards like this.
  15. ray_ray Mini-Sponsor
    The Philippines
    Gus .. Your garage qualifies you to receive a free ride from the Cebu International airport to your lodging of choice if you ever show up here.
