125-200cc '14 CR125 to Woods Weapon
Discussion in '2 Stroke' started by firedog55, Feb 7, 2014.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    you know that gas cap is gonna take a coupla weeks don't you? patience Miagi son:p
  2. firedog55 Husqvarna
    SouthEast, Missouri, USA
    '14 CR150
    Yam WR450F, Tri. S3, BMW K12, VTR
    That's OK, I have plenty to do now. Wax on-Wax off
    shawbagga likes this.
  3. firedog55 Husqvarna
    '14 CR150
    Well, I finally got started on the conversion. Today I got the 144 kit, the Lectron, CV4 silicone hoses, hour meter, and the WR tank on. I was about to get started on the EE radiator guards but it looks like an erector set operation and I didn't have the patience for it. No problems with any of the parts installation. Set the power valve linkage as advised by WB in one of the tacked threads, 3/4 from the top (best for woods riding).
    Ready for kit installation.
    Cylinder on.
    Kit on.
    Until tomorrow.
  4. Motosportz CH Sponsor
    Nice bike, shop and goodies! How fun.
    - Still pissed this bike disappeared from exsistance.
    sabortooth, jmetteer and shrubitup like this.
  5. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    howd the lectron fit up? no airbox deformation? what size are you running?
  6. firedog55 Husqvarna
    '14 CR150
    "howd the lectron fit up? no airbox deformation? what size are you running?"
    Lectron fit great, no problems, 36mm on advice of Kelly, best for woods riding.
    Today was frustrating though. The EE rad guards are a Rube Goldberg affair and don't fit. Turns out that the brace rods were to short, called EE and they knew about it, said they'll send me the right ones on Monday. The FMF Fatty stinger wont fit into the stock silencer, too large an O.D. Called Hall's, they said ship them (pipe and silencer) back and they'll check it out, send me another pipe if need be. Tried chamfering the inside of the silencer in the hope it was only burrs or something-no go.
    So the only thing I got accomplished was the Ricochet skid plate-fit perfect, easy install. Solid and looks like it will give good coverage. Think I need a Brake Snake after looking at the brake pedal clearance.
    Todays progress:
  7. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    cool spot for the hour meter but PITA to check hours isn't it? I may try find a similar spot but easier to check, maybe facing the air filter?! I gave up on them cause they always failed after a while from washing/rain/mud etc. hurry up & get that thing dirty would ya!
  8. firedog55 Husqvarna
    '14 CR150
    I'm a long way from getting this thing back together. I first tried to mount the Hr. meter on the right side of the steering head but the radiator guard was in the way. Then I thought about the cylinder head braces, but I was concerned about the vibration killing the meter. It's not a big deal to check it inside the air box/rear fender when you clean the air filter, and it's protected there. Also I didn't want the mounting screws(I don't trust 2 sided tape long term) protruding inside the fender toward the rear tire.
  9. Micfasto Husqvarna
    2012 TXC 310
    XR400, Vstrom
    I put the hour meter right on the tank in front of the gas cap (double sided tape). You will never miss an oil change with it looking right at you.
  10. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    My hour meter is mounted to the top of the rear fender, under the seat. It sits right behind the crossbar that the back of the seat sits on. That way, you just need to pop the seat off to check the display!
    I didn't run one at all last season (just the factory odometer), so I am very interested to see the hours vs. miles this year so I can estimate how many total hours are on my bike.
  11. firedog55 Husqvarna
    '14 CR150
  12. firedog55 Husqvarna
    '14 CR150
    Made some progress today, and had a couple of issues.
    1st. issue was the TM DesignWorks chain slider will not fit, the rear mounting points are way off. Sent it back for a refund. They said they
    thought it would work a on 125, although they never actually tried it.:eek:
    Rollers and Guide are fine.
    DID chain, SuperLite steel sprocket, 7602 axel blocks-no problem.
    2nd issue 7602 rear disc guard wouldn't fit in the caliper mount guide slot on the swing arm. So I removed a little aluminum with a grinder and file.
    Mounted up fine after that.
    Renthal FatBars, grips, and G2 hand guards went on no problem.
    UFO RMZ fender went on with a little drilling and Dremyl work.
    7602 front disc guard no problem.
    Enduro Engineering sent me an e-mail saying the longer radiator guard brace rods are in the mail, and hopefully Hall's will get the FMF Fatty pipe/silencer issue squared away tomorrow.
    So then all I'm waiting for are the BMP case guard, brake snake, HSP gas cap and the graphics.:) I'm starting to get real excited as this bike comes together.
    JAM, sabortooth and typeone like this.
  13. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    man that bike is pure porn:notworthy: . too good to ride! fuel cap couldn't be more than a week away at most surely
    sabortooth likes this.
  14. surfingboyo Husqvarna
    South Coast, NSW, Australia
    WR165XC
    new bikes are just soooo sexy!
    shame they don't stay like that long...
    :doh:
  15. firedog55 Husqvarna
    '14 CR150
    I found some more bling today-Zeta red anodized billet handle bar clamps with nylon inserts and a red anodized fuel cap vent.
    Spoke to Hall's today, they're sending me another FMF Fatty pipe and Power Core 2 silencer. The stinger on the first pipe was egg shaped. They convinced me I needed the FMF silencer to go with the pipe, I'm so easy:thinking:.
    shawbagga-I'm not worried about the fuel cap, it'll be the cherry on top of the sundae when it gets here.
    surfingboyo-That's why you take lots of pictures when they're new, so you can see the contrast once they've been used.:mad:
    BILLF likes this.
  16. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    That thing is looking pretty sweet!
  17. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    "That's why you take lots of pictures when they're new, so you can see the contrast once they've been used.:mad:"
    I keep mine pretty new looking for a very long time. Some guy last weekend sounded like he was complaining when he told me that my 300 looked too clean. I pointed out that I like to keep my bikes shiny and clean. Then he said that there were no scratches, or any dents or scrapes on the pipe. I told him that I don't like falling down.:rolleyes:
    sabortooth and Xcuvator like this.
  18. racerjake549 Husqvarna
    Cape girardeau mo
    CR125, TC250
    nighthawk 700s, 2x Piranha 190 pits.
    T
    Talk to me about exhaust before you buy anything. Scalvini pipe is absolute #1 performer on this motor option!! I have exact same bike and set up in garage. Been going strong for 2 years.
  19. racerjake549 Husqvarna
    Cape girardeau mo
    CR125, TC250
    DO IT!
  20. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    Nice job so far . Love your work. Your garage floor is way far too clean by the way.
