125-200cc 165 ring end gap
Discussion in '2 Stroke' started by shawbagga, Jan 4, 2017.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Put 2.5 hours of WOT grasstrack on the new piston today. Broke her in real good!!! Seems all good, no leaks, feels right, rear brake worked a treat. Left the PJ at 1 turn out & think that's where it will stay. Did about 80km to reserve(dry sand & fairly up her!). Forget where rod was but it's half a turn richer than where it was. No spooge at all(dry black muffler) but to be expected riding it hard like that.
    I'm currently running 12:48(13:52 ready to go on soon as 12 wears too quick!) but wouldn't mind a bit more top speed every now & then. Do 14t fit ok with BMP case savers, looks like it'd be close?!
    johnnyboy, wallybean and juicypips like this.
  2. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Anybody run a 14t front sprocket on 125/144/165? Any issues with clearance?
  3. Tentontimmy Husqvarna
    Caribbean
    2012 WR125
    Suzuki GSX-R1000
    I ran a 14t front sprocket on my 2012 165. It was fine.
  4. Tentontimmy Husqvarna
    Caribbean
    2012 WR125
    Suzuki GSX-R1000
    PS I ran the 14t sprocket on an otherwise stock bike. Can't speak to whether it would clear the BMP case savers.
    shawbagga likes this.
  5. Down Under XC Husqvarna
    Melbourne, Australia
    XC250 83', WR250 87','XC150 10
    WR165 10, 83 KDX 250,
    Hi Shawbagga,
    Any detonation issues with our fuel and what fuel are you using. I am still having detonation issues with my 165. I may have to consult the master Walt again.?????
    Mark
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    More than likely a timing issue, retard it a fraction.
  7. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Not that I've noticed Mark, Walt set squish at 1.5mm from memory before he sent it over. Run it on 98 & not too lean seems good.
    Hopefully get some good life outta this piston after seizing my first after 32 hours(completely my fault) then the lining on cylinder failed & oring blew out on the second after 16 hours. It looked like detonation or something bouncing around in top end(pitting in head & piston) but may have just gotten too hot.
    Walt got me back up & running. Confident this one will last otherwise I'm going back to 125. Fun bikes
    juicypips likes this.
  8. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    When's everyone replacing rings on their 165's? Walt sent me a spare so was thinking around the 30 hour mark? It gets ridden pretty hard(well for a clubman!). It's got 18 hours on it now. I'm kinda anxious to tear head off to check piston too!
  9. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    I'd be guided by the compression readings mate.
    Mine started at 205psi as a reference point for you.
    The general rule is do them when you've got around a 10% drop IIRC.
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    If that thing is still hauling your ass around shawry then it's fine!
    454x and shawbagga like this.
  11. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    I would put good money on the ring doing 50 plus hours before it wants changing if mine is anything to go by, even after 80 plus hours on one hardly saw any difference in the gap - was run on castrol A747
  12. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Mmmmm A747-exy but smells delicious!
  13. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I've got 60 hrs on mine, a few races and lots of WFO riding, and starting to feel like it's time. Compression test next, but I can feel the edge is gone and it doesn't pull as strong off the bottom. :cheers:
  14. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Wow 60 hour's a long time on small single ringer! Let us know how you get on Steve. I might leave it to 40 hours
  15. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    I know when I had my 165 - it wasn't running well and I checked the ring at 40 to 50 hrs and it had a really humungous gap - cant remember exactly now - I am not sure why that happened . From that experience Id check at 30 hours . Check the compression first
  16. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
  17. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    166 hours!!! I'm currently on 115 on 300's third top end & can feel it's lost power!
  18. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    :rolleyes: Twisted her tail again over the weekend and she didn't miss a beat. Def tearing it down soon though. 100 hours on the piston, so probably play it safe and send it back to Walt. Though if it looks good I may do another 30-40 hours on a fresh ring.
    shawbagga and juicypips like this.
