TE/TC 17 TE 150
Discussion in '2st' started by dartyppyt, Sep 1, 2016.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I used a number 115 out of my kit.
    Across from 115 are the dimensions:
    John Bunker likes this.
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Transferred my old air box vents over.
    I did have more inside but when I ran a muddy wet Harescramble, all that mud landed on top of my filter.
    What a mess so staying with side vents on top only. I also sealed up my air box and subframe with rtv when I took it completely apart over winter.
    hakkalugi and blink_618 like this.
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is where I strategically place some long pop rivets to keep subframe from pulling apart and letting mud in.
    You have to make sure you miss the side plate tongue and airbox grooves.
  4. wallybean Mini-Sponsor
    Montana
    Mud.....interesting concept but not seen here very often.:D
    Norman Foley likes this.
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Well least my helmet I painted up last year matches now.....
    blink_618 and wallybean like this.
  6. Norman Foley Husqvarna
    Yesterday....
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Had to reconfigure my intake to match my carb opening.
    Sometimes you think you did something and you didn't .........
    Sheet forgot to do this long time ago. It otta skoot more up top now!
    PForceJarvis and blink_618 like this.
  8. Notdoneyet Husqvarna
    Oregon
    TE 150 2017
    2006 DRZ 400, 81 HDFXS
    ^^^ sorry to ask but can you expand on this idea a bit more? Perhaps you know of a good 2T tuners handbook to point me at so I can learn about this stuff without bothering everybody?
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Notdoneyet,
    Not sure what is out there. Probably most of us are self taught thru years of trial and errors.
    Me, I never stop learning. I'm always trying to self teach myself or reach out and ask.
    Doesn't bother me at all when you guys ask questions. At some point someone was always kind enough to answer my ??????
    This is prob one of the best forums out there.
    I make mistakes too. My carb is bored, taper-oval bored. I forgot to match my intake to it.
    The stock intake is 38mm so mine had to be adjusted up to 41mm in spots. If not then carb flow hits the area and flow is held back.
    Wallybean
    Norm Foley
    And sooooo many on here are great resources.
  10. hakkalugi Husqvarna
    North East PA
    17' TE150
    You pop that baby & let er rip yet darin? Got to be close at this point! Bike looks awesome. Your just heating that pipe with a torch to get the bluing?
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Take your pipe and wire wheel it, till clean and shiney.
    Then take your oxy/acet torch, with small tip and heat it. You will see colors as you go.
    I try to get lots of purples in there. Then after I do an area. Take a rag soaked with 90 wt gear oil and rub pipe till it cools down. The gear oil will season it to keep from rusting. Then after washing bike, use a lot of Wd 40 on it or gear oil.
    Thanx ! It's getting close.
    hakkalugi and Norman Foley like this.
  12. PForceJarvis Husqvarna
    Hawaii, Oahu, North Shore
    2017 TE150
    Have you ever considered making a pipe cage to guard it from impacts?
  13. PForceJarvis Husqvarna
    2017 TE150
    bax3, dartyppyt, wallybean and 3 others like this.
  14. Pedec Husqvarna
    Sask.Canada
    Wow great race that looked tough and your bike was perfect for those nasty condtions. How long was total race.
  15. PForceJarvis Husqvarna
    2017 TE150
    It was only 24 miles but it took me almost 4 hours to complete. We got lucky it didn't rain for 2 days otherwise way more people would not have finished (over 25% of the people quit)
  16. tahoeacr Husqvarna
    TE150 '17
    KTM,Vertigo,Honda,Husaberg
    Awesome video!
  17. raylesk Husqvarna
    Livingston NJ
    17 tc 250
    Congrats on finishing that on a 150! Awesome video
  18. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Nice vid!
    Got me brake lines,shifter tip, v force should be here next week.
    Also trying some PVC shrink tubing on my clutch line. So we shall see how it turns out.
    If goes well, may use it on the brake lines. Shrinks at 50%.
    Now if I measured correct and goes over the banjo ends? Good ?
    Clutch line no issue at small end that screws into master.
  19. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Walt?
    Here is a question that you can prob answer.
    So you had the pre 17 husky 125/150.....
    Was your 14,15,16?
    Do you think that your existing skid plate on 17, would fit on those years?
    The blue I want is 14,15,16 style.
    The 17 blue is dark blue which is not color I want.
  20. wallybean Mini-Sponsor
    Montana
    It was a '16 TC125. It is essentially the same frame as yours but it doesn't have the mounting nuts in the frame at the front. The 14-16 TE's will be different.
    Now I had my Shoulder done on Wednesday and I am still in lala land with pain killers. Won't be riding again for at least 2 months and probably 4-6.:(
