TE/TC 17 TE 150
Discussion in '2st' started by dartyppyt, Sep 1, 2016.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Anyone on here need a set of these?
    EE radiator braces worked on my 17 TE150
    Sure they fit the 250 and 300.
    Can use stock loovers with rubber straps.
    $40 plus ship. (Sold to nother Husky Fan)
    In other words! I have a cool plan.....
    blink_618 and hakkalugi like this.
  2. hakkalugi Husqvarna
    North East PA
    17' TE150
    Wish those woulda popped up a couple weeks ago ebfore i got spankin new ones!
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Yeah! Would been good deal for ya. They only been on bike for lil over month.
    Gonna get different set, cause I got a cool plan that matches my silencer.
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is your ride report guys!
    Engine Is broken in and last main was 480. Did plug reading this am and noticed, titch of white on electro sides.
    So slapped in a 490 to be safe. We are at 55ish and this fuel is hard to do plug readings. It burns too clean.
    So, thought just take her out and pull handcuffs off.
    I thought last fall, I had bike running 10% over stock.
    Now! I don't quite know how words can describe it. Low end, has way more torque. That's why had to switch out rear tire. I was under tired and found one of my favorites, with good bite. It's breaking loose now like it should.
    Mid range. Definately increased overall and robust, No hiccups or nothing.
    Top end !! Was hoping I didn't loose any. Well, got even more. That's partially my error from forgetting to match carb inlet to my intake inlet, last fall.
    Sheet! I've created a monster! I'm not so sure that I want to do anymore to it.
    Dang bike got my attn couple times and though I was going down.
    Walt! Many thanks to your work in the RK tech head!
    Walt? Here is the plug on the 490 main.
    Here are my specs:
    RK Tech head insert.
    Ported exhaust booster ports (Forgive me but I had a hunch), cleaned/matched/polished main exhaust port and pipe matched.
    Fmf Fatty
    Fmf Shorty
    36/41mm TMXX V3 modified/polished carb and modified needle.
    Modified intake
    VForce 4 reed
    VP T2 race fuel 40:1
    Ngk BR9 ECMIX plug
    Yellow powervalve spring. 2 1/4 turns in.
  5. wallybean Mini-Sponsor
    Montana
    I think it is really cool that you have the masterpiece running. I don't know about anyone else but I couldn't ride it for fear of marring the piece of art. Sounds like you got exactly the feeling I had once I had my Lectron adjusted. Wish that fuel was available anywhere close to me. Really scary color on the plug, even lighter than mine. I hear ya that it is hard to read with that fuel.
    hakkalugi likes this.
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Bumped up to 500 main and got titch more out.
    I'm out of jets over 500+
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    This kinda tells you the fuel feeding this thing on 500 main.
    Now look at my tip and see what it is releasing compared to stock needle on left.
    blink_618 and wallybean like this.
  8. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Just front springs, rad guards ( going after them to look like my silencer), battery and some fine tuning.
  9. ripnriding Husqvarna
    Kingston, Ontario Canada
    2017 TX 300 and 2010 CR 144
    2007 husqvarna TE 450(sold)
    I'd be afraid to get that scratched up!!! Looks pretty bling man!
  10. NH-JP 2nd Fastest Old, Slow Guy!
    New Hampshire
    2017 TE300
    1988 Honda Hurricane,
    PM sent on Braces
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx!
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Walt, should have my Shorai Saturday.
  13. wallybean Mini-Sponsor
    Montana
    Seems to work as advertised. I have just been starting and giving little time to re-charge for a couple of months now and you would never know.
  14. ripnriding Husqvarna
    I was wondering if these new batteries needed to be on a tender when not in use........guess I should rig one up then?
  15. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I only use a battery tender on lithium batteries if they ever get low.
    I never leave one on constant.
    I take mine out for winter and store inside house.
    I usually make sure charged up before and then after storage.
    Rest time bike takes care of it, unless something drains it.
    Sure others will jump in on their thoughts too?
  16. Notdoneyet Husqvarna
    Oregon
    TE 150 2017
    2006 DRZ 400, 81 HDFXS
    LiFePO are a bit more forgiving regarding the charging procedure (compared to LiPO batteries found in the RC hobby world) but the best advice is to use a charger made for that type of battery as the internal cells need to be balanced for max performance.*
    * Disclaimer : Having said that I don't have the proper charger at the moment for my LiFePO batteries.
    My other bike has a LiFePO battery with a small constant current drain from the speedo unit. I've found it dead (a huge no-no for a LiPO, and all batteries for that matter) and so now keep an eye on it. Every 4-6 weeks if I haven't ridden it in the winter it gets low and I put it on a BT Jr for a lead acid battery (not the best method) for a few hours to bring it up. Then ride the bike normally. Most times if the bike is ridden every couple weeks the battery stays charged.
    Definately don't want to leave the new style batteries on a tender made for a lead acid battery for extended periods (more than a few hours). My shop is kept at about 60 to keep moisture off my machine tools so the environment isn't as bad as if I was in an unheated shed.
    I will likely end up getting a fancy charger as they do keep the battery alive longer.
    dartyppyt likes this.
  17. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Think I'm going to do a polished center Husky logo, on these radiator guards. Then incorporate the same colors, as my silencer.
    NH-JP likes this.
  18. Norman Foley Husqvarna
    I have had excellent luck, with the WPS lightweight batteries, in both my Husaberg TE250 and KTM 200XC-W. Less expensive and hold a charge well, even in the cold.
    raylesk likes this.
  19. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Why you tell me this now that my Shorai is being delivered today?
    No, just giving you hard time! I did look at the WPS ones, but the CCA's were lower and figure I'd go more from high compression head.
    There are a lot of great comments out there about WPS batteries.
    Norman Foley likes this.
  20. Norman Foley Husqvarna
    I knew they weren't blingy enough for you cool guys....
