TE/TC 17 TE 150
Discussion in '2st' started by dartyppyt, Sep 1, 2016.
  1. hakkalugi Husqvarna
    North East PA
    17' TE150
    Why did you cover up the bottom portion of the tank? Looks like a good time!
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Looks like it's runnin sumo tyres with all that mud!
    dartyppyt likes this.
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Nice ride!
    I wouldn't mind adding a nother!
  4. raylesk Husqvarna
    Livingston NJ
    17 tc 250
    Thought i might be regretting my 150 buy after riding 250 but was opposite...i was happy to get back on 150! It rips now with better jetting and power valve tweaking :)
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    It is a translucent tank and and keeps the sides nice from getting all scratched up and stains embedded in plastic.
    I do it if I think it is going to be muddy.
    You can cut a notch down towards front if you want to see your fuel level.
    Thoughts are this winter is to produce an aluminum tank. Just to see if I can do it?
  6. hakkalugi Husqvarna
    North East PA
    17' TE150
    Ive got some nice rub marks in mine already... Makes sense..
  7. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Ah, heck. They're only new once.
  8. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    When you gonna pull the trigger for yours?
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Been while since I messed with pipes and silencers.
    There are three pipes I have in mind? Scalvini , FMF Fatty and HGS. I am wanting power from bottom to top.
    Silencers are bout one choice from Scalvini.
    About one for HGS.
    FMF, got Powercore titanium? Turbine Core? Shorty? So some imput as to overall power be appreciated?
    Noise does not bother me because helmet muffles it anyway. Neighbors live qtr mile away and like that too!
    So any imput from you is appreciated ?
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Walt, I'm going 44 on my front springs and from 4wt to 5 wt up front. Same oil level.
    wallybean likes this.
  11. hakkalugi Husqvarna
    North East PA
    17' TE150
    I ran a gnarly chamber & shorty silencer on my ktm, the bottom end was insane on it.
  12. blink_618 Husqvarna
    2017 te150
    2013 kx250f
  13. blink_618 Husqvarna
    2017 te150
    2013 kx250f
    The fmf fatty will give you more broad power through power curve instead of boosting just top or bottom. Combine with shorty silencer which is design to enhance bottom mid range.It will be little louder than the turbinecore 2.1 and is not spark arrested. I think I'm going to go with fatty/shorty combo and make my stock pipe spark arrestor with little screen from Lowes just get through inspection then switch back to shorty. I cannot speak to the scalvini as have never owed one.
  14. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    If it helps any? I use a wood bit to drill my side cover vents. Then trim edges with exacto knife.
    I glue the vents in with silicone.
    But in the back side. I drill two small holes against the side cover. Then insert these lil clevis pins I got at farm store.
    Guarantees that I won't pop them out.
  15. wallybean Mini-Sponsor
    Montana
    Are you looking for more air supply? The stock air box is very well sealed and I wondered about restriction.
  16. hakkalugi Husqvarna
    North East PA
    17' TE150
    I drilled a couple 4-5 holes in the front of my air box facing towards the front of the bike, its not much but it does feel restricted even with that little extra ventilation. Where dod you get those vents from?
  17. Picklito Husqvarna
    Washington
    Well, I've been logging lots of miles on the '14 300 lately and it works so well I just may wait another year. In fact, it works so well that I just feel greedy wanting a new bike. For now I think I'll follow the development of the new platforms and maybe think about an '18. Loving' this thread, though...
  18. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    They reckon the '17 300 has a restricted airbox and opening up yields a big power gain ( video on youtube ) so it may be worth testing the airbox design - but it sounds like its going real good to me
  19. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Run it with airbox cover off n c?
  20. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Yes, I was having issues with not drawing enough air for my carb. I also switched to spray filter oil instead of bottle and pour on stuff. The filter don't like over oiled. So first thing came to mind was venting side panel just like bigger two strokes and 4 strokes. I took my side cover off and noticed my carb ran crisper. So after I drilled holes. I took some smoke and as I cracked throttle wide open the smoke was drawn in. We did same on sons FC 250.
    Picklito and wallybean like this.
