TE/TC 17 TE 150
Discussion in '2st' started by dartyppyt, Sep 1, 2016.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Yes, I see your point cause I wouldn't mind a 250 2 stroke.
    Thanx on compliments and from others as well.
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I emailed Scalvini.
    Said there pipe is smooth on bottom like stock then comes on around mid and more top end.
    They also said to combine it with their shorty if I want more bottom and overall power.
    Kinda sounds maybe like FMF fatty and shorty combo?
    Their shorty is carbon fibre and real light but it's pricey! Might put less stress though on composite sub frame?
    blink_618 likes this.
  3. hakkalugi Husqvarna
    North East PA
    17' TE150
    That chamber looks awesome, but knowing me, itd be dinged up and dented in no time.. Fatty & shorty sounds good, have you considered the gnarly?
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Kinda a cool pic that race photographer took.
  5. wallybean Mini-Sponsor
    Montana
    Well I am picking up the TE150 at Bend at the Northwest Husqvarna gathering from Bill! :thumbsup::cheers::applause: Can't wait.
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Awesome! Your gonna love it!
    Take some pics! Also, wonder how many times you will look at it on the way home?
    Michael Ryan likes this.
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I ordered a fmf shorty to just throw on my stock pipe.
    Only $116 bux so figured what heck.
    Hoping to try it for Sunday.
  8. hakkalugi Husqvarna
    North East PA
    17' TE150
    Where can I get a plug for this thing? Everywhere is either overseas or out of stock...
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    See if bike shop has a:
    I use this one for jetting:
    Use a NGK BR9ECMIX plugs
    Then plop u big bux one back in.
  10. blink_618 Husqvarna
    2017 te150
    2013 kx250f
    Try AOMC in west Virginia they usually have everything or slavens racing. My local shop has a box of them.Let me know if you still cant find one.
    hakkalugi and dartyppyt like this.
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I took my float height to 9mm
    But also have my carb bowl nut mod already done.
    Basically you are drilling 4 small holes in bottom of float bowl above the oring where it seals when you tighten nut.
    Then once nut is tighten and marked with a punch for alignment.
    You take a pick and mark nut through 4 holes you drilled.
    Then remove your nut and drill through nut where you marked so holes align.
    Makes sure you alway have fuel down by main jet.
    blink_618 and wallybean like this.
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Nother color scheme and me new snorty shorty.
    It short alright!
    wallybean likes this.
  13. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Surprised the bowl nut isn't drilled already. This seems to be something they used to do, but musta stopped.
  14. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Yes, they used to on older Tmx. I'm surprised they didn't do it on the newer carb.
    I will probably get a deeper bowl nut this winter.
  15. Rollie Wolk Husqvarna
    I rode one two days ago.
    Impressions
    Light as a feather
    Suspension has never been touched and worked really well, was nice in the rock and not too soft in the whoops (I weigh 190 lbs). Xplor forks didn't beat me up and the rear stayed planted.
    Handling was not twitchy like my KTM's.
    Real bad flat spot going into the upper mid but other than that I was very impressed.
    Talk about an engine with no vibration :D
    I wish I had one.
    raylesk and dartyppyt like this.
  16. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Had good time racing today and jetting is almost spot on.
    Ran really crisp through the tight woods, with crisp acceleration all way up top.
    Husky guy said bike sounded really awesome.
    So here is a tribute to Charles Bronson an old Husky guy!
    Bike ran flawless ! Problem is : other riders brought two too many, of them other brand bikes!
    View: https://m.youtube.com/watch?v=8XkHsinz7oU
    hakkalugi likes this.
  17. hakkalugi Husqvarna
    North East PA
    17' TE150
    Appreciated, ill give a call around this week and see if I cant get one.
  18. Picklito Husqvarna
    Washington
    hakkalugi,
    Your avatar is "so last week"... just sayin!
  19. Norman Foley Husqvarna
    Maybe I missed this here, but on the KTM Talk 150XC-W thread, they have been talking about PV springs and seem to like Blue best. None (No Color) is standard spring. Part numbers for different springs...
    PV Springs
    Green 5483 7072 100
    Yellow 5463 7072 300
    Blue 5463 7072 500
    Red 5483 7072 000
    None 5043 7069 050
    blink_618 and dartyppyt like this.
  20. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Good find Norm!
    My manual only says that two are available?
    Standard and yellow? But standard, yellow and red are available for 250+.
    I would think the red and blue makes the powervalve, even open faster?
    I may have to play around a lil but don't know if I can get close to my carb response/combination with yellow spring.
    Right now, I'm building carb number two based on my other one. I need a micro sized drill bit, smaller than a paper clip and can't remember the size I need. I know I wrote it down, but who knows where I put it and can't find the bit?
