1972 450 engine questions
Discussion in 'Vintage/Left Kickers' started by DeathFromAbove, Dec 23, 2016.
  1. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    Went up and got all my husky stuff and will compare the drums. Going to the Oily Pipes Swap meet this weekend to hope fully sell some projects. Just google OILY PIPES.
    justintendo likes this.
  2. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    ute load of projects there allright;) hopefully someone else's after the swap
  3. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    They all run except the rm80 on the left.
  4. squid on a 300 Husqvarna
    York Springs Pa
    72 WR 250 79 CR 250
    GAS GAS 300 Trials 2 KTMs 2 Hodakas
    Death...you get your transmission issue solved yet? Inquiring minds want to know...good meeting you at oily pipes
  5. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Hi Squid.. Congratulations on your Best of Show... Combat Wombat!! That bike of your is the Best I have seen and I've seen a plenty. Again Congratulations! Yes Squid, FINALLY changed the 5/6 and 4th on the main shaft. No pic at this time but after making yet another jig for observation, found those were badly damaged ...seems I wasn't in TUNE to the condition of their edges (or rotational axis)(was turning the crank backwards most of the time:thumbsdown:) and that's why the 3/4 shift fork got a good bluing, in gear but jumping as power over came the edges as well, putting a lot of pressure and pressure builds heat on that fork. Seems when I was on a spending spree on another site I bought a box of Husky Trans Parts. I found a set of gears from a 76 250/360. That set had the needed gears. Both the gears were still in layout blue, as they had been machined to repair the tolerances. Thanks JAY(the name etched into them).Good thing they didn't sell at the meet!! And the trans movement into 1st and locking at the meet was my carelessness in aligning the pawl and ratchet on the shifter/step feeder. The pawl dropped and jammed the steep feeder so it would not return to shift again! That's my STORY, and I am sticking with it...until proven wrong!:cheers: I have a call to Forest Stahl to see if he can repair the damaged gears so I can use them in the other 450 motor I have. Got the tank out for pinstripes Then decals and clear tomorrow. Will take pics. Then I'm gonna ride the crap, outta it Fri and Sat. Also, It was very excellent to meet so many like minded and Interesting people at the Oily Pipes Show and Meet. Have Great Holiday and DO NOT RIDE like I do:busted:.
  6. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    You know, now that I think about it, the 3/4 shift fork was not holding at the solder joint (post 34) and I bought a replacement from Vintage Husky. So now it comes clear! The one that was in the bike when I got it was damaged from the 5/6 set bouncing off the 4th wheel and broke the solder joint! Life is hard.. But it's harder when you stupid. It took 7 times in and out of the bike and two jigs to figure that out. I knew I'd win.
  7. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    Sounds like you got the problem figured out, that's good to hear. Mechanical mysteries can be frustrating to say the least.
  8. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    We'll see if they hold this weekend when I whip it. Here's pics of the powder coated tank back with pin stripe, and homage to my cat. Powder was hard to feather so I left the edge. We'll see how it wears. Decals and clear today. Yeah Team! 20170831_063510_resized.jpg 20170831_063519_resized.jpg
  9. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Finally, the tank is done. Here's some pics. It's sleeping in the welding rod box overnight. We'll see what the temp is in the morning. I'm guessing about 108 f. A few flaws but a far cry from what I started with, and only about 100$. Still have put it on the bike and load up for the hills. I'll put a cheap tach/totalizer on it cause she's new. And I have to fix the window in the truck, electric will not roll down, nothing worse than no highway air. Oh yeah, a nice buck out front this morning, he has a twin running around with him. Hope they stay for the rut. I'm hungry now. 20170831_113424_resized.jpg 20170831_115300_resized.jpg 20170831_115306_resized.jpg 20170831_121405_resized.jpg
    Crashaholic likes this.
  10. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    The BUCK. 20170831_065052_resized_1.jpg He looks Tasty!
  11. Crashaholic Husqvarna
    Tank looks real good for a $100. I take you did the powder yourself? Did you cure it in a garage oven or the wife's?
    And the clear can't be powder or I would think the decals would look pretty funny about now. So what is the clear, urethane?
  12. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Within 5 deg. and looking good. Powdered at a factory we service, they use the orange for huge cable trays and it looks real close. this is a great clear, very forgiving, just coat every 15 min til empty. 20170901_071328_resized.jpg 20170901_071418_resized.jpg 20170901_073930_resized.jpg 20170901_074119_resized.jpg
  13. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Looks good in the sunlight. All loaded and headed out. It's the first cold snap, so I brought 2 sleeping bags and a comforter. Brrrrr. Going to ride her like I was 23. 20170901_082028_resized.jpg 20170901_082104_resized.jpg 20170901_082140_resized.jpg 20170901_094944_resized.jpg
    Steve-F and justintendo like this.
  14. Crashaholic Husqvarna
    Nice job! :thumbsup:
    Steve-F likes this.
  15. Crashaholic Husqvarna
    Well I hope this doesn't mean your next post will be from a hospital bed. :eek:
    Not so worried if you were talking about the Honda.
    DeathFromAbove likes this.
  16. squid on a 300 Husqvarna
    York Springs Pa
    72 WR 250 79 CR 250
    very nice job! bike looks great...now for a few scratches and stone chips to give it that lived in "I'm a ripper" look!
  17. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    bike is looking right!
    im starting to wonder if we need a "post up your husky hauling ford truck pics" seems like we have more than a few :thumbsup:
  18. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Back from the weekend and you'll be glad to know I still have 4th gear! I only rode her like I was 45, couldn't remember what 23 was like! Seems the timing is too far advanced as I came to a tight corner she backfired twice, I had the clutch pulled in and stopped. I was like wtf! I revved it and no signs of illness, so I let the clutch out and started going backwards? I killed the motor immediately. Now, I knew instantly what had happened, but couldn't believe it. I read about it here somewhere that the motor can run in reverse if the timing was too far advanced and it lumped over on kick, but I was moving forward and downshifting to first. So she must have gotten to the top of the stroke while in gear then popped the other direction as I slowed the engine. It only happened that one time so now and forever will be remembered as "That Weird Thing" that happened at the farm. Other than that, she needs the idle jet one size up and the needle clip down one. She's pretty lean on the bottom. I couldn't get her to instant rev on a downhill when set like the manual. More fiddling! Also got the output sprocket off the other wr450 I have, and was pleasantly surprised to find the trans in almost unused condition, all bearings look good and spin freely, the rotor end is sheared but I have another. The right side bearing is good also. will take some pics when I pill the clutch side and pull the crank for rebuilding. Hopefully it won't need much more than seals. Then I'll try to campaign it next year and leave the 0008 motor bagged for resale. Going to need some advice on that. Justintendo, that truck has moved innumerable motorcycles and coolers so we'll need a bigger page and Crash, don't let the 2002 xr650r fool you, I don't call it General Patton for nothing.
    Trenchcoat85 likes this.
  19. Crashaholic Husqvarna
    Sounds like you had a good time. That's was counts.
    I know the xr650 is a heavy bike and takes more effort to ride in tight stuff like the woods but out here in the desert that bike can be a lot of fast fun.
    When you got the top end together did you do a leak down test. Every engine I've rebuilt has had some sort of air leak when doing a bench top leak down from an intake gasket, base gasket, crank seal, or seal retainer. If timing was to far advanced I don't feel it would start easily on the first/second kick like in the vid in post #94. The problem may be leaking gasket, a worn slide, plugged carb circuit, or something like that. :thinking:
  20. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Yeah Crash, he's a brute in the stuff out here. One hour is like four on this old carcass. I did leak test when I first put it together, but you make valid points so I'll do it again before I change the carb settings. It's been apart a lot so things may have changed since the second start video. But now how do I explain " That Weird Thing" that happened at the farm? I'll presume is was drumk. Anyway here's a couple of pics of the motor stand I made to find the 4th gear problem. The plexi looked good, but wasn't tight enough to observe the gears in action. 20170905_103134_resized.jpg 20170905_103204_resized.jpg This one rotates when the front bolt is loose, so you can put it in a lot of positions. It's a bit problematic to put the motor on and off but it's nice for doing the building and crank insertion. Doing that on 2x4s was awful! That's the other 450 in there now, with a five speed. Everything looks spiffy in there to me.
