1972-75 engine, big bore 88mm?
Discussion in 'Vintage/Left Kickers' started by Krudd, Oct 10, 2018.
  1. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    Since you have a good one go with the Mikuni. If I'm not mistaken the 501 Maico of that era had a 38mm so I would think the 38mm Mikuni would be perfect. To large a carb and the air velocity is reduced possibly rendering the carb problematic.
  2. Krudd Husqvarna
    Sweden
    89A 510TE, 89B 510TE
    '81 Yamaha XT500
    Turns out the wrist /gudgeon pin is worn unevenly so will need changing. He found a new bearing for it but not the pin itself yet.
    Any tips on what engines had the same 20mm size pin? It measured: Outer diam. is 19,92 mm, inner 13, length 70,75.
  3. Crashaholic Husqvarna
  4. Krudd Husqvarna
    Sweden
    '81 Yamaha XT500
    Thanks for the link! :cheers:
  5. Krudd Husqvarna
    Sweden
    '81 Yamaha XT500
    Found a NOS pin for a 450 engine at a local dealer so problem sorted! :thumbsup:
