1973 Husqvarna 250WR
Discussion in 'Vintage/Left Kickers' started by DeathFromAbove, Dec 17, 2020.
  1. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    Couple more pics!
    motomwo likes this.
  2. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    So are these outside clutch covers Aluminum or Magnesium. I have few that are pretty broken at the kick lever stop and would like to have them welded! I got the steering stops welded on these 2 frames and had them re blasted. and welded the right size triangles under the pegs. Tomorrow I'll tape them up for powder. Hope I remember to tape the Serial Numbers:doh:
  3. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    Wow, nice work my friend. Its been a few years since I did a resto, I forgot the time it takes when there are many repairs.
    About those steering stops from Tritophy, the ones pictured on his website are for the pre 72 frames. The MJ and MK are straight across the front opposed to angling back. The angle will allow the steering to turn farther and the top triple clamp bolts will hit the tank.
    All the clutch covers I have acid tested were magnesium. Not sure if aluminum was ever used.
    DeathFromAbove likes this.
  4. Vinskord Husqvarna
    400 CR
  5. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Well looks like I should mock a set of Tripples and Tank to see what has to be added to the stops Before I Powder coat. And I'll test the cover with white vinegar to see what happens. Thanks for the heads up[! Chris
  6. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Getting the wheels Spoked !!
    Crashaholic likes this.
  7. Crashaholic Husqvarna
    When doing a restoration lacing the wheels is always one of the last things I do, really don't care for it. But when they're all laced up and true its a pretty good feeling of accomplishing something so damn tedious. Your wheels are looking great by the way, nice work.
  8. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    I got the spoke from Buchanan, and I think I have a problem with the odd ball set up. Stay tuned
  9. Crashaholic Husqvarna
    When lacing a Husky rear wheel I always have to refer to the service manual for the procedure. Its one of those things I'd have to do often to commit to memory.
  10. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Yeah even with the manual it is not easy. I have 9 spoke that are about .5 " too long. Will advise Buchanan. Tried flipping the rim and working it in reverse. Same spokes are long. They are the up spokes on the brake hub side. Forgot to take a pick in Mt frustrations.
  11. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    Chris, I had the same exact problem with a set of Buchanan stainless spokes while using the same hub you have. This was many years ago when I restored my 76 175XC. I was able to lace up the wheel completely and then cut off the extra long spokes. Shouldn't have to do that but that is what I ended up doing. In the end it all worked out.
    Marty
  12. Crashaholic Husqvarna
    Are you comparing the 9's length with the other spokes when they're off the hub or just based on the fact they stick out from the rim 1/2"? Nine is the number of spokes on one side of the rim going in the same direction. I've run into this before and it turned out to be my incorrect lace pattern.
    Heres the spoke length as seen in the parts list. 189mm qty 12; 201mm qty 18; 159mm qty 6.
  13. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    I called Buchanan and they said to relace the hub. So I did, granted the new wheel is not an original, it's a Italian knock off. Not as beefy or drilled at the correct angles. But the up spokes are too long by about 3/8". I have to finish to take pick to send to tech support. I think the wheel is marginal at best. After I get the 411 from Buchanan, I will probably swallow my pride and change the spoke angles by drill to get them at least pointing in the correct direction. If no joy then I'll toss it in the recycling. And write off 130$. I've drank more in an evening.
    mysery1 and ajcmbrown like this.
  14. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Got some of the polished parts back. Getting closer.
    motomwo and mysery1 like this.
  15. motomwo Husqvarna
    Imbler Oregon
    Those polished pieces are going to look so nice on the bike! Chris you just keep out doing yourself from one project to the next. Can't wait to see it when it is done!
    Marty
  16. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Haha Marty, it's only money!!
  17. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Finally got to rebuilding the swingarm shock mounts. I'll have my certified welder do the real welding, then they are ready for powder.
  18. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Swingarm is Done and Powdered, also got the triple tree bearing cups and races and stuff back from the plater!! Gonna start to assemble the 250 and 450 this weekend. Ordered tires and got a front that is 5.3 yrs old and a rear that is not the matching tire. They are both going back and I will buy from a reputable dealer and not off Amazon!! Live and Learn!!
    motomwo likes this.
  19. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Started assembly today.
    motomwo likes this.
  20. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Got the engine in and have to decide which tank to use.
