1973 Husqvarna 250WR
Discussion in 'Vintage/Left Kickers' started by DeathFromAbove, Dec 17, 2020.
  1. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    Regarding the drive chain being so close to the shock, it surprises me how long Husky used that set up. The 1975 ML GP frame was the first year the close tolerance was addressed.
    Your project started easy enough. Must have the timing in a sweet spot. :thumbsup:
    DeathFromAbove likes this.
  2. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
  3. Crashaholic Husqvarna
    Sounds rich. Did it clean out once it warmed up?
  4. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    I haven't checked full throttle but have to check all the fasteners and the head torque. Then another warm up and check. Then I'll start messing with the Carb or switch it with a new Mikuni. I added extra oil for the brake in so that may be the excess smoke and possible blubbering. But when it starts to rev that CR Piston and Rod get to the pipe very quickly! It has an old Bing on it that I think I just sprayed out with Brake clean. So I'm very happy with that as It's gonna get sold anyway. That's why no Wassel Tank Or DG Pipe. And no Chain Rash on the Ohlins!!
  5. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Crashaholic and mysery1 like this.
  6. Crashaholic Husqvarna
    Too much fuel in the low rpm range. Which Bing carb do you have? The later model Bings had larger jetting including the pilot, the main, and jet needle. These were carbs 1/36/114 and 1/36/116. The earlier pre 75 250's had the 103 and 106 Bings and were jetted leaner.
  7. Crashaholic Husqvarna
    That pipe is going to look bitchin' once its finished. The fact that it tucks further under the tank will save the leg from getting roasted when standing up.
  8. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Crashaholic, mysery1 and motorick like this.
  9. motorick Husqvarna
    Jacksonville, OR
    1974 400 CR, 1987 250 XC
    1973 Norton Commando
    Looks awesome Chris! I especially like your one-kick start walkaway! A 'drop the mike' moment : )
  10. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Not bad for a Broken old fat guy. Headed to a Non-discript building in the am. A Ton O Parts. Do ya feel Lucky? :cheers:
    motorick likes this.
  11. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Search was a bust for early stuff. Except a 73 wrcades with the lower end and a set of 73 cr cases.
    But if you need 390 stuff let me know.
    No wheels or such fixins. Few later 75-80 frames.
    I am loooking for frame MJ- 00438 to match my 0008 2021 motor that was sold to Ron Bohn an ISDT rider.
  12. Crashaholic Husqvarna
    Finding that frame sounds like a 1 in a million chance. Can't help but wonder; what would someone want with the frame/chassis without the motor?
  13. Crashaholic Husqvarna
    Its said that the older you get the faster time speeds up. I'm at the point that a year feels like a week, so it would now take me 25 years to restore a bike, or would it be 3-1/2 days, IDK. :confused:
  14. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    One in a million so true.
    Frame is probably destroyed by now but it don't hurt to look.
    And yeah the time is flinging. I still got a pile of bikes and motors to do. Too much fun!!
  15. DeathFromAbove My Cat Says AREAR!
    North New Jersey
