1977 360 Auto ressurection
Discussion in 'Vintage Restoration Projects' started by ajcmbrown, Apr 5, 2020.
  1. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    I removed the top end yesterday, I can't help thinking that this is low hour bike, Mahle piston, the bore looks very usable, piston measures at 81.82, 81.92 is standard, not bad after 43 years! It was always my intention to split the cases to replace seals etc, but since the crusty rust on the barrel studs fell into the crankcases, it wasn't my decision anyway, the big end feels great, mains are smooth but I'll check them once I split the cases.
    Have a look at that ring gap! I knew compression was down, but I didn't expect just over 4mm end gap.
    I'll have a friend mic the barrel for taper etc and go from there.
    IMG_20200406_123221.jpg IMG_20200406_132149.jpg IMG_20200406_140134.jpg IMG_20200406_132154.jpg
  2. ajcmbrown Husqvarna
    I made up a tool to hold the clutch hub while undoing the 32mm nut, it turned out to be quite loose, 30nm at most, the first gear drum looks very good, the shoes will be dressed with a hacksaw blade as per the manual, but no bad news here.
  3. ajcmbrown Husqvarna
    Next up was the main hub and cluster, it lifted out easily, and the shoes will get a clean up and there is some wear in the main hub, but I'm told it's quite serviceable.
    I'm still thinking that this is a low hour bike....
    The engagement gear dogs and main shaft look quite good as well actually better in real life than the pics suggest, I don't think there is any reason why this transmission can't be used as is after cleaning up the grooves in the shoes, not often things go this well!:cheers::applause::banana:
    IMG_20200406_163139.jpg IMG_20200406_200017.jpg IMG_20200406_200034.jpg IMG_20200406_201135.jpg
    DeathFromAbove, Steve-F and 86 400 XC like this.
  4. ajcmbrown Husqvarna
    Can anyone tell me the stock shock absorber eye to eye measurement? I have searched but I get varying lenghts mentioned, I thought they were 14" but I'm not sure, the Koni shocks on the bike are 13.5".
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Lookin good!
    ajcmbrown likes this.
  6. redman Husqvarna
    Pa
    77 360 automatic, 77 WR250
    ec200 Gas Gas
    I believe my original shocks where 12.75". I replaced mine with 13.5" shocks, and they work fine.
  7. ajcmbrown Husqvarna
    That's interesting, as this one has 13.5 or 345mm shocks as well, were they Girling originally?
  8. ajcmbrown Husqvarna
    I'm also in need of a air filter cage if anyone has one they would sell?
  9. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    Original shocks were Girling 12.9 inches center to center length.
  10. ajcmbrown Husqvarna
    Thanks guys, much appreciated! I have sourced a filter cage as well.
  11. ajcmbrown Husqvarna
    Have any of you guys discovered 3 fork seals per leg before? I removed three35x47x7mm seals per leg, was this an attempt to stop them leaking? Apart from the obvious stiction issue, it's actually kind of clever.
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    No! You know what saying goes? Everything bad comes in threes! It’s not my bike so that won’t be the case!
    DeathFromAbove and ajcmbrown like this.
  13. ajcmbrown Husqvarna
    In that case I'll call it 6 per bike instead of 3 per leg!
    Some cleaning and inspection today...
  14. ajcmbrown Husqvarna
  15. ajcmbrown Husqvarna
    Some parts to be blasted and powdercoated.
    Steve-F likes this.
  16. ajcmbrown Husqvarna
    Can anyone tell me the paint code for the frame and the green tank?
  17. ajcmbrown Husqvarna
    Hopefully my "no spark" issue should be a thing of the past, stator tests well, coil not so good, cut the end off the lead at the cap and all good now, I just can't test on the bike it at the moment as my engine is spread all over my workbench.
    dartyppyt likes this.
  18. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    If no one comes up with a paint code? Go look at some paint chips for old Porsche colors. I think you will find the green there.
  19. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is another one:
    This is from 1976.
    Almost looks like Porsche Speedway green?
    I think I seen where there was some green left in your filler neck. Inside of tank? What about underneath in frame tunnel?
    Tip, always match your paint chip up with color out in the sun.
    If you do have paint under tank, see if someone could scan the color.
  20. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here another tip:
    For the chrome panel. Polish the chrome. Then make a stencil out of duct tape to cover the chrome panel area. Sandblast/glass bead the tank anywhere there is chrome left, just enough so primer and paint can bite into it and adhere. Sand from sandblaster won’t go through the duct tape, unless guy is using high pressure.
    That’s why you see all these old husky tanks with paint flaking off of chrome. Worst thing you can do is paint over chrome unless you etch it.
