1977 360 Auto ressurection
Discussion in 'Vintage Restoration Projects' started by ajcmbrown, Apr 5, 2020.
  1. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    My guy has a mixing room like you see on the car shows but maybe I just lucked out. Good luck. My place is called Gavins, in Patterson NJ
    ajcmbrown likes this.
  2. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    I have a guy in another town nearby, I'll take my tank to him to try to match the bit of green in the frame tunnel.
    dartyppyt likes this.
  3. ajcmbrown Husqvarna
    This may look very unorthodox, but I needed a solution to hold my centre case gasket in place until the gasket cement sets, I normally wouldn't use gasket goo on a centre case but the one I got from Dave at Tritrophy was so out of shape, there was no way it would go back together with the gasket sealing the cases.
    Steve-F and dartyppyt like this.
  4. ajcmbrown Husqvarna
    Crankcase assembled, now for the transmission.
    dartyppyt and Steve-F like this.
  5. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Looks good Tony, those paper gaskets shrink with age, i let them soak in water and they swell back up. Then assemble while stile moist.
  6. ajcmbrown Husqvarna
    Why didn't I think of that Chris? The centre gasket was trying to curl up badly, but it's now in place.
    Tomorrow I'll clean the grooves in the 2-3-4 shoes and install the transmission and clutch cover and sprocket cover.
    I'm getting very impatient about my package from RTR Moto, last scanned in San Fran 11 days ago and no more progress since.
    I still don't know why my pics from my phone end up rotated....
    Tony.
  7. ajcmbrown Husqvarna
    My next dilemma is fitting the main hub into the cases, is there a specific process for this? I've tried with the output shaft in and out, with both left and right covers removed, it just doesn't want to fall into place. If I try to fit it with the output shaft in place, my mainshaft will only go in so far, leaving a gap of around half an inch between the hub and crankcase, no amount of rotating the internals makes any difference, if I install with the output shaft out, it will go all the way home into the blind bearing on the opposite side, but then I am unable to fit the output shaft without 1/4 inch protrusion past the cases, I can install both clusters with both covers off, all gears seem to mesh, and both sit in what appears to be the correct position in relation to the covers and engagement tab but when I try to fit the output shaft cover it pushes the mainshaft back toward the left side cover, I've checked everything I can think of and still cant get this sucker in place. It came out very easily with a little jiggling so I didn't expect any issues fitting it back in.
    I split the cases, checked the bearings, they were in nice shape, replaced the seals for the sake of it and it went back together really well.
    Any help appreciated,
    Tony.
  8. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    Tony - Have you remembered to lift and rotate the gear engagement rod on the right side. The main shaft won't go in otherwise.
  9. ajcmbrown Husqvarna
    Yes, shaft all the way up and rotated, no contact with the engagement plate.
  10. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    I think i had to tinker with mine too, I pretty sure you have to instal the primary shaft assy. first then the output shaft do you have the output plate off and like was said the engagement lever up, i think i remember that was where i had trouble, i's kinda funky to get the lever to fit where it is supposed to if i remember because of the engagement gear spring tension. Good luck You downloaded the auto stuff from Michel?
  11. ajcmbrown Husqvarna
    Michel's information was great, the workshop manual doesn't mention anything about how to re-assemble the transmission, making me think it is a very straight forward job, but this one is being quite difficult. I've thoroughly checked the engagement lever but there does not appear to be any contact at all, I've tried installing with the sprocket cover off and on, clutch cover off and on, with first gear hub off and on and it just won't seat properly, I can get the two clusters to sit in what appears to be their correct postion, gears meshed evenly, but the sprocket side cover simply will not go on without pushing the mainshaft toward the clutch cover, I can see that the mainshaft is entering the needle bearing, I've taken a very short video of the engagement leverwhen the shafts seem to be in their correct position. I'll have another look at it tonight, but I just can't see any reason why it won't sit correctly. I thought maybe there was a known trick to get it in, bit it seems not.
    View: https://www.youtube.com/watch?v=Ca5U3ueo1UE
  12. ajcmbrown Husqvarna
    If I install the output shaft first, I get this situation
    And it I install the main shaft first I get this,
  13. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Did you make sure the 2,3,4,basket is all the way on the main shaft? Have you tried spinning the output shaft while pushing the assembly together? Have you put the main shaft in and the primary clutch on the crank, and install the cover then see if the output shaft will install while spinning? Just throwing crap on the wall, don't give up it came out, it will go back in. Chris
  14. ajcmbrown Husqvarna
    Walked into my workshop tonight and it just fell into place, must remember how I was holding my tongue when I did it! View attachment 100982
  15. ajcmbrown Husqvarna
    I tried to compensate for my pics being flipped and obviously failed!
  16. ajcmbrown Husqvarna
    Thank you all for suggestions, as you can see it's now together, but I have a question regarding the spring cover, is it meant to be in contact with the springs or just clear them in the case of a breakage?
    My cover is hard up against the springs and I tend to think the new new lateral load "could" contribute to spring breakage?
    Can anyone either confirm my thoughts or put my mind at ease?
    Tony.
  17. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Good job getting it together there Tony it's surprising when it just clicks together like that that spring retainer is not made for the 7677 autos it's made for the later models but I put mine in a brake and bent it out and test fitted a bunch of times until it was enough of a gap that I was happy so it wasn't touching the springs Good luck You're moving ahead Chris
  18. ajcmbrown Husqvarna
    Thanks for the helpful advice Chris, I'll do the same, I haven't torqued the nut yet, once I saw that it was pushing on the springs I thought that it couldn't be doing any good, best to ask questions about assembly than have to deal with a bigger mess later!
    Tony.
  19. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    As for the sideways pics and videos, before you take the pic or video choose the auto rotation on your phone! Good luck, and so glad you got her together! Chris
  20. ajcmbrown Husqvarna
    Thanks Chris, it's on so I'll try turning it off and see what happens.
