1977 360 auto
Discussion in 'Vintage/Left Kickers' started by DeathFromAbove, May 28, 2018.
  1. redman Husqvarna
    Pa
    77 360 automatic
    ec200 Gas Gas
    Yea, you got it. Glad I could help.
    DeathFromAbove likes this.
  2. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    So I had the motor in the frame and found it would not roll over, it did before. I pulled it out and pulled the cylinder and the motor at the bottom of the stroke would not budge. Pulled the side cover and was pleasantly surprised at the condition, very nice , no broken springs and the shoes look brand new! Tried to move the crank, no go . Looked at the crank bearing behind the main clutch and it looks great. Pulled the seal retainer on the ignition side and there it is, a rusty bearing, the stub don't look good either. Ahhh, another full disassembly. At least I can rebuild the crank! It needs paint too!
  3. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    Gear box looks really good and that's the bit that matters with an Auto, looks to me that the ignition shaft will clean up okay as well.
  4. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    I took the motor apart today. I found a good ignition side crank bearing in my stuff, so that will get installed. The rest of the bearings in the motor look good, even the freewheels are in excellent condition. I will put the crank on the lathe and video the run out before disassembly and again after reassembly. I will be interesting to see what the difference is. I hope the big and small bearings and pins are serviceable. Then a slight sand blasting and fresh paint. New seals and a complete set of gaskets. It should look awesome in the newly powder coated frame.
  5. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    More pics.
  6. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Got the 360 crank rebuilt, both the stubs were replaced. The rod big pin and bearing are in good condition. I took video of the crank before and another of the final tuned crank. Once I get the new bearing in the case, I'll be able to reassemble the center cases and crank.
    View: https://youtu.be/5xUZJlzb5XI
    oldbikedude likes this.
  7. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Does anyone know the original length of the shocks for this bike ? The shocks I have are ohlins and I don't believe they came original on this 360 Auto. Thanks Chris
  8. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    I used Alcaro&Alcaro in Montclair NJ. I'm taking this stuff in this week after cleanup. I'll let you know what they charge me. The last batch was smaller and they charged 75$. So I figure around 100$ for this batch.
    How do you like the link on this brake?
    Also Drew is done with my shocks, should pick them up Friday.
  9. oldbikedude Husqvarna
    Honey Brook Pa.
    Wow, brake link for going around corners.
  10. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    12.9 inches measured from center to center of the eyes.
    Marty
  11. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    I went out to WER on Thursday and picked up my shocks from Drew. I just want to tell everyone that Drew is the nicest, most humble guy I have met in a long time. He was patient and answered my questions and concerns. He is KNOWLEGABLE and was concerned with my application. On top of that, when he had a question, HE Called Me to find out what I thought! Novel concept!! I just want to thank him for his work and the service he provides to us fellas who can probably do a shock rebuild, but are reticent to jump into that pool. Thanks Drew PS I recommend his service to everyone!
    ajcmbrown likes this.
  12. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Also has anyone seem one of these spacers for the air box? It is not shown in the parts diagram. Aftermarket? Oversized air filter? It's about a half inch wide. Chris
  13. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    Aftermarket for sure, it got the cover up off the air filter to open the air flow on the stock filter.
  14. ct cr430 Husqvarna
    Connecticut , litchfield county
    1981 cr 430
    2007 honda crf450
    Had that on my 78 390 , mine was part of a kit from k/n .
  15. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Was the k/n filter bigger or what? 86 400 xc makes sense with the separation from the filter. Just want to know what I can about it. Can I still get a k/n filter set up for this box? thanks for the info. Chris
  16. markt2 Husqvarna
    Nevada
    1976 250CR (times 2)
    Several vintage Yamahas
  17. markt2 Husqvarna
    Nevada
  18. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Thank Mark, this came with the cage and the spacer so i don't think they had the lid. I like the idea of the solid/car style filter like on my 450. Maybe I can find a crossover at the auto parts store. Thanks for the good work guys, now I feel lazy!:o
  19. redman Husqvarna
    Pa
    77 360 automatic
    ec200 Gas Gas
    Yes, all are correct above. The spacer is for the K&N filter and you do need the lid for it as well. The K&N is a little fatter filter than the foam one, thus the need for the spacer. I have one on my '77' Auto as well. These where the ticket back in the day. Many people don't care for them these days. I'm still runnin mine though.
    DeathFromAbove and oldbikedude like this.
  20. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Decided to just clean up and paint the old plastics.
    jimspac and oldbikedude like this.
